Old 05-17-2009, 03:08 AM   #1
sturner
sturner is on a distinguished road
Default brake boot squeel
wondering if anyone has had this problem. When im driving a very high pitched squeel comes from the boot on the brake pedal bracket that goest through the firewall. When i hit the brakes it gets louder and if press hard enout it goes away for a second then comes back. It has to be a vacuum leak as thats the only thing that could make a squeel that bad (at least imo) but i was seeing if anyone had this problem and a known solution. Thanks.
sturner is offline   Reply With Quote
Old 07-29-2011, 12:15 AM   #2
sturner
anyone ever heard of this or had this happen?
Old 07-29-2011, 02:28 AM   #3
El Supracabras
El Supracabras's Avatar
Sounds like you may have a ruptured brake booster diaphragm.
Old 07-29-2011, 03:05 AM   #4
sturner
That makes sense. I've never dealt with that before and can't find it in the TSRM (brake booster section doesn't say anything about it), is it a hard fix?
Old 07-29-2011, 03:18 AM   #5
sturner
is the diaphragm the arrow in the picture? If so then I'll have to pull the whole damn thing off.
Old 07-29-2011, 04:03 AM   #6
El Supracabras
No, the diaphragm is inside the metal housing. You will have to change the whole thing. The bolts are way up under the dash, its not hard to change, just a bitch to get to the bolts.
Wilwood Big Brake kit ARZ Parts For Sale 7 09-21-2009 07:28 PM
87 supra brake lights ministrytrav MKIII Supra 4 11-23-2005 08:53 PM
