Old 03-20-2009, 11:19 AM   #1
Paul_NJ
Paul_NJ is on a distinguished road
Default Replacing Timing belt
I've been reading the timing belt removal procedure in the TSM, and it seems like they take off the belt by removing tension on the belt tensioner, then remove the cam and crank timing gears, then they reinstall the gears, and finally put the new belt on and tighten it up with the tensioner . Why remove the any of the gears at all? Is it just to replace the seals? That's not mentioned in the TSM. Otherwise it would be a lot easier to just switch belts. How difficult is getting the gears off and changing the seals? I see they call out a SST for removing the timing gears. Any suggestions on that?
Paul_NJ is offline   Reply With Quote
Old 03-20-2009, 01:11 PM   #2
IHateHacks
IHateHacks's Avatar
You don't need to remove the cam or aux shaft gears to replace the timing belt.
Why the TSRM tells you to remove the gears when replacing a timing belt.....because the TSRM is a joke, that's why.
Old 03-20-2009, 04:52 PM   #3
burton51m
burton51m's Avatar
If you don't want to remove the gears then just skip that step. To change the seals you have to take the camshafts out.
Old 03-20-2009, 07:59 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
IHateHacks is right; you don’t need to remove the pulleys. As you know the most difficultly part is removing the crankshaft pulley. You would have thought Toyota would have designed the bottom cam belt cover in two sections to enable the belt to be changed without removing the crankshaft pulley. If you need to change the cam seals at any time; remove the cam covers and you will see a section of the camshafts that have two flats on it to place an open-ended wrench or spanner, this will hold the camshaft in place whilst undoing or tightening up the cam pulleys. Lots of good info HERE
Old 03-21-2009, 12:20 PM   #5
Paul_NJ
Thanks for the replies. Bill, that link you shared with the series of images is terrific, thank you. That's also a great site . . . found an electonic parts manual on there. Once I buy 3 more M8x1.25 bolts I'll get that crank pulley hole spacing measured.
Old 03-21-2009, 05:35 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
These are useful sites Paul if you didn’t already have them Repair Manual and Parts and Guides
Timing belt tensioner HELP ! lobosupra MKIII Supra 1 12-11-2008 11:52 PM
Broken Timing Belt detroitsupra MKII Supra 3 03-10-2008 11:06 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
Timing Belt Change, Do It at Home mrnickleye Supra FAQ 2 09-19-2006 06:24 AM
Timing belt rubbing against lower front cover adamh88 MKIII Supra 4 01-05-2006 11:08 PM
