Old 03-13-2009, 03:18 PM   #1
Paul_NJ
Paul_NJ is on a distinguished road
Default Vacuum/air lines
I'm pulling things apart to replace my top engine oil seals, and all the tubing is lot's stiffer than the last time I did this (10 years ago . . . no surprise there). After too much struggling I'm about to just start slashing those large diameter hoses connecting the BOV. Before I do that
1. On any other car I'd just cut them off and just use regular heater hose to make replacements. Any problem doing that?
2. I ordered a vacuum tubing set from Hose Techniques. Anybody know if those are included in the kit? That would be nice.
3. My Turbo's been pretty sluggish. Is there a procedure to test that BOV while I have it off?
4. I'd appreciate suggestions on other things I might check/replace while I'm going in.
Thanks. Just needed a little hand-holding
Paul_NJ is offline   Reply With Quote
Old 03-13-2009, 07:45 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
# 1. I don’t see a problem with that Paul, providing they are the correct internal size to make a good tight fit.
# 3. Procedure for checking stock BOV SAAB Blow-Off-Valve
Quote “To check your BOV, remove your stock BOV and blow through the main two 3/4" hoses. If you can breath straight through it, your BOV is broken” Front page website Link
Old 03-14-2009, 03:37 AM   #3
Paul_NJ
Hi Bill
Thanks for coming to my aid once again. I really appreciate your willingness to help.
Paul
Old 03-14-2009, 11:32 AM   #4
ddmcse
ddmcse's Avatar
Cool
no bov hose in the kit . you should check the connector for the "3000" pipe it's common to crack on the underside
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-14-2009, 09:01 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
The BOV to the 3000 pipe is in the miscellaneous section at the bottom of the page in this Link if you need the diameter.
Old 03-15-2009, 11:25 AM   #6
ddmcse
ddmcse's Avatar
Cool
to be clear I mean the 3 inch connector for the 3000 pipe to the throttle body , hose techniques sells a replacement for that . it's common for that piece to get hard and crack causing you to loose boost
My Supra KiXGaS
Easiest Way to Hook-up Turbo Oil Lines? Benesesso MKIII Supra 1 03-24-2006 05:46 AM
Newbee: Question About Vacuum lines.. Alejo_NIN MKIII Supra 3 01-12-2006 07:18 AM
Break Lines TRAFIK Non-Generation Specific Questions 2 01-09-2006 07:42 AM
