Old 02-09-2009, 08:23 PM   #1
TurboSupera
TurboSupera is on a distinguished road
Default Atf Iv
I'm planning on draining the transmission fluid and power steering fluid and replacing it, obviously. This is from an automatic transmission. I bought an 89 Turbo about 3 months ago, with about 82,000 miles on it. I figure this is something easy to do and should probably be done. Here's my question. Is it o.k. to use ATF IV; this is from Toyota? My friend had some leftover when I helped him work on is IS300. I thought I read somewhere here that someone had problems with the steering when they used ATF III instead of ATF II. I also have another question. Sometime it appears that the power steering isn't working.....usually when I'm parallel parking....the wheel get hard to turn. Any ideas? I thought I'd go the less invasive route and change and bleed the system, first. Thanks.
TurboSupera is offline   Reply With Quote
Old 02-09-2009, 09:04 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Toyota ATF IV and dexron II are OK. I made the mistake of using dexron III some years ago and ended up with a loud buzzing noise coming from the tyranny, (dexron III is a GM fluid and not meant for the A340 boxes) I quickly drained it out and filled up with dexron II. You probably already know this; when you undo the train plug you will only be able to drain out about 2-3 litres, most of the fluid is held in the torque converter. Toyota ATF IV is the best, but expensive in the UK.
Old 02-09-2009, 09:17 PM   #3
btwilson86
Super Moderator
btwilson86's Avatar
As for the stiff whell, you might want to check that the vacuum lines that run to the powersteering pump are connected. They're supposed to speed the engine up a little bit at an idle so that your steering is easier at a dead stop
Old 02-09-2009, 09:39 PM   #4
TurboSupera
Thanks for the info. Yeah, I know I won't be getting a complete flush, but since I don't know what's ever been done to the car or if things were maintained, I'm taking it one step at a time. I want to make sure everything is up to par before I start modding anything. Coolant's been done, bleeding the brakes are next, then oil and filter change and the diff. Took me a long time to get rid of the smoke smell. I guess the prior, prior owner was a smoker. I'm sure I'll be asking more questions. I'm dreading the "blown head gasket" hopefully I'll be able to hold out for at least two more years.
