Old 02-01-2009, 08:21 AM   #1
rinso
rinso's Avatar
rinso is on a distinguished road
Default I've got no EGR system
Due to a blown head gasket I've taken the head off my 7M-GTE to discover it has no EGR cooler, which is a plate on the back. I've also got no EGR valve. Instead I have a little plate blocking off the exhaust hole where the EGR cooler would cover effectively ignoring the EGR system altogether. Does anyone know of any reason why I shouldn't keep this setup? I've driven my car for two years without a problem, besides the headgasket. That was always going to happen though.
rinso is offline   Reply With Quote
Old 02-01-2009, 03:35 PM   #2
mirage83
If you've got a JDM ecu, no problem, as JDM engines didn't have the EGR system. It's only when you've got a USDM engine or an ecu which is setup for an EGR to be present that it's a real problem.
Old 02-02-2009, 06:03 AM   #3
rinso
rinso's Avatar
It is indeed a japanese import, so I guess I am good to go! You little beauty! Thanks for the input.
Old 02-02-2009, 08:12 PM   #4
CyFi6
Just cause the engine is JDM doesnt mean the ecu is. Check it.
Old 02-10-2009, 03:53 AM   #5
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation
So if I wanted to block off my EGR I would need a JDM ECU not the U.S. spec ECU?
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 02-10-2009, 03:55 AM   #6
CyFi6
^ Yes. Probably easier to get your egr working.
Old 02-12-2009, 08:36 AM   #7
tsupranami
tsupranami's Avatar
tsupranami is on a distinguished road
California models require a small resistor to be wired into the EGR wiring plug to fool the ECU into thinking the EGR is still there. It will show the Check Engine light and store a fault code if the EGR is removed and there is no resistance in the system. Non-California cars don't care whether it is hooked up or not. I've had mine disconnected for several years now, with absolutely no ill effects. My buddy has the same car (89 7MGTE), but his was a Cali car, so his check engine light came on when we ditched his EGR. We googled a fix somewhere, got a resistor from Radio Shack, and fixed it all up, also several years ago.
tsupranami is offline   Reply With Quote
Cold Start System Testing (hard starting) mrnickleye MKIII Supra 12 11-13-2010 08:32 PM
Cold Air system? Black'88 Non-Generation Specific Questions 10 04-22-2006 02:40 AM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
disarming factory antitheft system 89 supra cacarolturbo Non-Generation Specific Questions 2 05-22-2005 11:15 AM
