Old 11-16-2008, 09:33 PM   #1
Jet Krosswind
Jet Krosswind is on a distinguished road
Default Smoke coming from sides of car when sitting.
Hey all, Just recently did a valve seal and gasket job to fix the blue smoke escaping from my exhaust in the morning, but another problem still exists.
Sometimes when I am idleing at a light I will notice smoke out of the bottom of the car and sometimes out of the exhaust. It is not constant and doesn't look white. By the way, when I put my car in park it idles at about 1500 rpms. Is it my ECU? or a Manifold problem?
Thanks,
~Jet
Jet Krosswind is offline   Reply With Quote
Old 11-17-2008, 01:23 AM   #2
Chambers
Chambers's Avatar
Does anything else leak? When my power steering line leaked it would spill some smoke out from the exhaust side.
As for the 1500rpm idol, it may be from a defective water temp sensor. There are two temp sensors, one for the gauge cluster, and one for the ECU warm up cycle. I'm not saying go out there an start throwing parts at it until something fixes it but just consider that.
Good luck.
"Stuck in the 80's"
Old 11-17-2008, 03:33 AM   #3
Jet Krosswind
Antifreeze tends to leak. Might that be it? Oh and I recently had my water pump replaced, could something with that cause the high idleing?
Old 11-26-2008, 04:54 AM   #4
nickapaso
nickapaso is on a distinguished road
I recently fixed a leak from the bottom of my dipstick tube. The o-ring at the bottom. It would leak a little at idle and also a lot during heavy boost.
nickapaso is offline   Reply With Quote
Why is this smoke coming from the turbo? Turbotuner2.3 MKIII Supra 3 11-12-2007 03:30 PM
Supra sitting at Car shop, what should I do?? scalla1477 MKIV Supra 11 08-14-2007 08:12 PM
wisp of smoke under boost? mrvetten MKIV Supra 10 12-17-2006 12:57 PM
NEED HELP!!-my 89 mik3 emitts blue smoke quickfingas MKIII Supra 1 05-04-2006 12:54 AM
Oil n smoke from turbo wolfen Non-Generation Specific Questions 0 10-30-2005 12:27 AM
