Old 11-04-2008, 01:49 AM   #1
5upra lov3r
5upra lov3r's Avatar
5upra lov3r is on a distinguished road
Default can i put turbo in my na?
just wondering if i can put a turbo in my na supra
i wanted to swap for 1jz but dnt got money
but w.e
wat would i have to buy and do?
~86 1/2 NA~
5upra lov3r is offline   Reply With Quote
Old 11-04-2008, 04:21 AM   #2
salomon68
salomon68's Avatar
salomon68 is on a distinguished road
You are better off doing the swap. I have an NA and looked into doing the same thing. It's a long, tedious, time and money consuming process. The NA engines (7MGE) don't have a lot of internal components that the turbo engines (7MGTE) do. If I ever want a turbo in my NA, I will do a swap. If you want a turbo engine, check out Jazz Pro Parts. They have the 7MGE, 7MGTE, 1JZ, and 2JZ engines.
salomon68 is offline   Reply With Quote
Old 11-06-2008, 05:52 AM   #3
shiftysupra
shiftysupra's Avatar
PLEASE!!! Use the search tool... This has been covered 100x and counting... www.4CEFED.com That should clear up some questions. If you have any other questions that are not already answered if you search feel free to ask, we all could help
Your best bet is to buy a complete engine. You would then need a KVM and IC and piping. ECU and matching harness depending on the motor and ECU year. and since you have an 86 you would need front cross-members and engine mounts. The link I provided gives you pretty much a complete list...
Old 11-06-2008, 07:49 AM   #4
salomon68
salomon68's Avatar
listen to shiftysupra, it has been covered, A LOT.
Old 03-25-2009, 10:49 PM   #5
NevvBy
NevvBy is on a distinguished road
YES, LISTEN TO SHIFTY.. OR if your young and have ideas.. Do as i did a month ago and turbo ur NA... Its not as hard as doing an engine swap.. I spent less than $2000 on it.
NevvBy is offline   Reply With Quote
