Old 10-14-2008, 04:07 PM   #1
RR_180sx
RR_180sx is on a distinguished road
Default Car wont crank pls help
The car is an 88 Supra 7mgte. When i turn the key into the on position i hear a few clicks then when i turn it forward to crank it nothing happens at all. All the lights on the dash work and everything seems to have power. It has a brand new starter and battery so i dont know why im not even gettin some sort of response. Any ideas would be much appreciated. thanks.
RR_180sx is offline   Reply With Quote
Old 10-14-2008, 10:20 PM   #2
OkieRA29
OkieRA29 is on a distinguished road
Check your fuses first. Then check the lines to the starter. Should be one bolted on and one that plugs in. Check the battery with a voltmeter. Sometimes you will have enough juice to run stuff, but not enough to crank. Check the connections at the battery. This happened with my wife's camry. Turned out the battery terminals were a tad loose. Start with the fuses and go from there.
OkieRA29 is offline   Reply With Quote
Old 10-14-2008, 11:59 PM   #3
walker
walker's Avatar
walker is on a distinguished road
Cool
I can give you a few options to check out,1st battery cables loose,corroded or worn,2d starter relay faulty(ex.canada a/t),also check the clutch start switch if u have it on(m/t only),neutral start switch faulty (A/t only),fusible link blown,starter or ignition switch faulty.as you said battery and starter are new I don?t see any other option.
good luck
walker is offline   Reply With Quote
Old 10-15-2008, 12:08 AM   #4
walker
walker's Avatar
it could be that for one of them danm switches car wont start
A Little Story about a crank bolt abhattan MKIII Supra 17 03-28-2013 01:06 AM
Crank Pulley Removal go.stfu MKIII Supra 4 07-12-2007 11:16 PM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
Crank shaft pulley.. MA70_858 Non-Generation Specific Questions 3 07-28-2006 04:47 PM
