Old 09-14-2008, 07:55 PM   #1
supravan
supravan's Avatar
supravan is on a distinguished road
Default its new 2 me
hello guys i have a 89 astrovan that i put a 88 turbo supra motor n and i need 2 no if i can put a newer intake manifold on it? like a 1JZ intake manifold or anything else u guys can think off, cause i hate tha way the intake pipe go's across the valve covers so any help wood b appericated
supravan is offline   Reply With Quote
Old 09-14-2008, 09:06 PM   #2
supravan
supravan's Avatar
come on guys i no some1 out there can tell me if i can or not
Old 09-14-2008, 09:34 PM   #3
Busted Knuckles
Busted Knuckles's Avatar
I've been looking for something, too. The closest I've found is a 1jz-7m hybrid. They cut the 1jz manifold and the 7m itake manifold at a point where the intake runners will match up to the 7m intake runners. Then, weld them together. The key is to find a 1jz intake and a good machine shop willing to do it.
Old 09-14-2008, 09:40 PM   #4
supravan
supravan's Avatar
i have some1 2 weld it back 2gether 4 me so got that covered, now im wondering what if anything i wood have 2 change on the 1JZ?
Old 09-14-2008, 10:13 PM   #5
Chambers
Chambers's Avatar
If you have the capacity to weld then it may be easier and cheaper to just make a front facing intake manifold, with a larger throttle body.
If not then modify your current intake manifold to a front facing status, as in cut open the front side of it, then weld the old TB hole up and put a new flange on the front side of the manifold, that way you retain all your stock engine parts but have the front facing intake.
Good luck.
"Stuck in the 80's"
Old 09-15-2008, 03:45 AM   #6
supravan
supravan's Avatar
if u have an idea of what i wood need 2 build a new 1 plz share the info or point me n the right direction. also its goin 2 b a cover vehicle so it has 2 look super clean i have a guy thats goin 2 make me a brand new harness and wire the motor up 4 me so all i got left is the intake manifold issue and the clutch pedal issue, since a van is auto and my trans is 5 speed anyways thanks 4 ur help
Old 09-16-2008, 12:34 AM   #7
Chambers
Chambers's Avatar
Well you will need some aluminum tubes and sheets, I have a quick SolidWorks 3D rendering of one, its by no means to scale I just threw it together. The red lines in the first pic are where
the welds would be for the tube and sheets.
Here is an example of a FFIM using the stock lower intake manifold on someones car.
"Stuck in the 80's"
Old 09-16-2008, 01:35 PM   #8
supravan
supravan's Avatar
thanks alot and where u find that picture at i wood like 2 get ahold of that person and ask him question about his intake manifold
Old 09-16-2008, 08:04 PM   #9
shiftysupra
shiftysupra's Avatar
chambers your awesome. gonna go buy the tubing to make one :] pics soon
Old 09-16-2008, 09:32 PM   #10
supravan
supravan's Avatar
chambers if u made 1 the way i needed it how much wood you charge? your best guess. and just let me know at my email danielwhly@yahoo.com and then i could send u pics of what i have done so far and u could get an idea of how much room i have 2 work with and thanks again for your help
