Old 09-13-2008, 04:46 AM   #1
mkiiisupra
Default Wiring Electric Fans
Whats a good way to wire up two electric fans with a temp switch?
I want it to only run with the ign in the on posistion
1990 Toyota Supra Turbo A/T
Old 09-13-2008, 11:58 PM   #2
mkiiisupra
Just want to know a Safe 12v switched signal from the IGN to wire into. Any of the existing A/C electrical wiring would work since i removing that system anyways
Just not sure of a good place to tap into
Old 09-14-2008, 12:53 AM   #3
Chambers
Chambers's Avatar
What about the fuse panel where the AC fuse is, I forget if its the left or right panel but if you tap into that you can get your 12v source.
Good luck.
"Stuck in the 80's"
Old 03-13-2009, 04:58 PM   #4
SilenceboneSupra
SilenceboneSupra is on a distinguished road
HHHHMMMM Sorry to bump this thread but I have mine hooked up to a 12v relay. So it's drawing from the battery direct instead of the IGN wire. I don't trust it.
SilenceboneSupra is offline   Reply With Quote
Electric Fan? mkiiisupra MKIII Supra 24 06-18-2010 08:26 PM
Electric fans fulljapan Non-Generation Specific Questions 4 08-14-2007 03:28 PM
-Belt driven fan +Electric Fan(s) Burn N' Up MKIII Supra 7 11-04-2005 02:37 AM
