-   -   Newb from VA (http://www.toyota-supra.info/forums/mkiii-supra/12228-newb-from-va.html)
the1silverbullet 09-12-2008 07:29 AM
Newb from VA
Hi guys! just thought i would finally join the forum instead of searching through it!!
I have a 88 supra w/ 130xxx miles that did have a BHG as well as the "oil on top of spark plugs" problem.
im just a regular mechanic so doing things of this nature aren't really a problem, i just dont know all the gritty details!
Either way, i just REALLY wanted to say "Thank you" to IHateHacks for all his contributions to MY project as far as Tech info goes. I replaced my BHG and torqued it down to 82ft lbs, drove it for 854 miles, yanked off the intake/valve covers, checked the torque again, and its been 4,000 miles and not a single problem with the head gasket OR the pesky oil on the spark plugs problem!
anyway, thanks for all the help you guys had no idea you were providing to a complete stranger!!!
the1silverbullet 09-12-2008 07:33 AM
oh also want to say thanks for the thread about the "water holding wheelwell" on the driverside fix and the STUPID toyota car alarm fix! the car alarm still works but i can turn it off with the key in the ignition and i can actually START the car!!! WOOT!! thanks again!!
