Old 09-10-2008, 12:50 PM   #1
mkiiisupra
Default Removing my A/C Sytem need help
Redo'n my entire cooling system and the oil cooler won't fit anywhere. So decided to just remove my A/C System
Any tips on going about this?
1990 Toyota Supra Turbo A/T
Old 09-18-2008, 09:57 PM   #2
Just take out all the under hood things. leave the under dash things in there.
Old 09-19-2008, 06:23 AM   #3
CyFi6
Get the system sucked down if you have any refrigerant in there before you rip it out. Plug all the lines going into the cabin to keep moisture out in case you ever want to put the ac back in
Old 09-22-2008, 10:08 PM   #4
mkiiisupra
Easier than it looked, got it all out and plug'd the two lines going into the interior. Now i have plenty of room to mount the oil/tranny coolers still working with routing these damn SS lines seems i will need more fittings ;(
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Having Trouble Removing the Steering Wheel Chambers MKIII Supra 3 06-30-2008 01:03 AM
removing a 7mgte from MK3 tokis MKIII Supra 2 11-17-2007 03:34 AM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
Removing the SAFC-2 MDellboy420 MKIII Supra 0 01-27-2006 03:02 PM
