Old 09-07-2008, 10:12 PM   #1
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
Default knock sensor rewire gone bad??
OK, so I just finished with my knock sensor rewire. Went to put my battery back in. I connected the negative, then when I put on the positive, something near the passenger side TEMS actuator buzzes and the temp gauge is spiked up, and the battery and check engine light are on(and the key isnt in the ignition.)
1988 supra turbo. In process of modding:Roll cage, seats, dp, 3" intercooler, fuel upgrades, and turbo upgrades next.
tak2099 is offline   Reply With Quote
Old 09-07-2008, 10:56 PM   #2
Stupra
Stupra's Avatar
Stupra is on a distinguished road
Sounds like a ground issue. Make sure your wiring job isn't exposed and touching anywhere. Did you run a whole new wire from ecu to knock sensor?
When life passes you by, DOWNSHIFT!
3 inch exhaust, cometic head gasket, arp studs, lexus afm, 550's, custom front fed intake manifold, FM intercooler, daily driven at 12 lbs.]
Stupra is offline   Reply With Quote
Old 09-07-2008, 11:07 PM   #3
tak2099
tak2099's Avatar
yes, ran whole new wire.
Old 09-07-2008, 11:10 PM   #4
tak2099
tak2099's Avatar
unsure if i hooked my starter up right. do you think that could cause it?
Old 09-08-2008, 12:21 AM   #5
Stupra
Stupra's Avatar
I suppose it's a possibility. Especially if something is grounding out. You can have the WEIRDEST issues when it comes to that
Picture Of Knock Sensor Locations ravenmaster MKIII Supra 10 01-31-2012 03:37 PM
Starting isssues and spark knock Q's spudz29212MKIII MKIII Supra 65 05-30-2008 06:44 PM
Engine knock @ 1700-2300 rstutler MKIII Supra 8 03-07-2008 07:36 PM
Rod Knock kewlcoconut MKIII Supra 20 01-13-2006 08:39 PM
Knock sensor..........ebay. rnoswal MKIII Supra 0 11-06-2005 07:24 PM
