Old 08-31-2008, 03:50 PM   #1
cgreiner
cgreiner is on a distinguished road
Default Spark Plug Change
I just purchased new Bosch Platinum 4 plugs and want to install as I was having some issues from a ancient plug. Does anyone have a torque spec for install on a 87 turbo ?
cgreiner is offline   Reply With Quote
Old 08-31-2008, 05:35 PM   #2
I don't know if those plugs are to be used with our vehicles, but to install plugs use 16mm Plug Wrench and torque to 13 ft-lb as stated in the TSRM
Old 09-01-2008, 10:48 AM   #3
carfanatic89
carfanatic89's Avatar
Im currently using the bosch platium 4 plugs and I like them there is something that is messed up with my car before the upgrade but I did noticed a definate hp increase. I also got some ngk wires and those also help alot.
Supra Engine Powered Dragster
Old 09-02-2008, 08:23 AM   #4
Stupra
Stupra's Avatar
Stupra is on a distinguished road
A little late but I'm pretty sure you don't want to use platinum plugs in the turbo supra. Apparantly they burn TOO hot. This is just what i've been told from a few reliable resources
Stupra is offline   Reply With Quote
Old 09-02-2008, 04:14 PM   #5
Chambers
Chambers's Avatar
Yea, I would never run any Bosch plugs in a Supra of any kind, go for some NGK Iridiums, they will be a little more expensive but well worth it, they are high quality plugs. I don't have Iridiums but I have their regular plugs and set of their wires, they are both great!!
Good luck.
"Stuck in the 80's"
Old 09-02-2008, 09:47 PM   #6
Grandavi
Grandavi's Avatar
Good luck.
Be very careful with Iridiums. The slide gappers will damage them as they are soft. (that's the warning I had with them) But definitely go with Iridiums.
Old 09-16-2008, 04:33 PM   #7
supraman62
supraman62 is on a distinguished road
Are iridiums OK for NA Supras?
supraman62 is offline   Reply With Quote
Old 09-16-2008, 07:58 PM   #8
Chambers
Chambers's Avatar
Yea, the NA will run them nicely.
"Stuck in the 80's"
Old 09-16-2008, 09:20 PM   #9
Mahonri
Mahonri is on a distinguished road
What about the E3's with diamond fire technology? Im not sure since I have not looked them up for the supra, but what I was told from a friend that races old school muscle, they work like a charm and have really nice power increases. e3sparkplugs
Update: They do have them for all years/models for the Supra. Interesting comparison that the series "Horsepower" did between the E3's and I'm not sure of the other brand.
Mahonri is offline   Reply With Quote
Old 09-16-2008, 11:11 PM   #10
Grandavi
Grandavi's Avatar
Im not an expert, but I believe that platinum spark plugs will perform as well as E3's, so the E3 should be ok for a Supra, however, I dont know if they will outperform the Iridiums...
Broken spark plug! HELP! supraman121 MKIII Supra 2 10-02-2006 08:40 PM
spark plug change supfoo514 MKIII Supra 4 06-30-2006 07:41 AM
new mk3 owner, spark plug galley full of oil!???? katillidie MKIII Supra 6 03-24-2006 05:09 AM
spark plug wires kewlcoconut MKIII Supra 2 03-19-2006 07:45 AM
spark plug change ? frank323 MKIII Supra 1 04-03-2005 07:03 PM
