Old 08-16-2008, 05:43 PM   #1
89MkiiiSupra
89MkiiiSupra is on a distinguished road
Default Supra makes wierd rattling noise after 3000 rpm on every gear HELP!
Hey guys, so check this out, i got a great deal on this supra for 4500. basically this guy rebuilt the motor and it has under 10,000 miles on it. he did alot of mods including
New Air Compressor Jun 08 $ 225.00 New A/C Drier Jun 08 $ 45.00
New Radiator Apr 08 $ 211.00
New Alternator Feb 08 $ 93.00
New Wheels Feb 08 $ 751.04
New Tires Feb 08 $ 725.00
Air Cleaner Hose Feb 08 $ 55.22
Lower Radiator Hose Feb 08 $ 31.00
HKS Metal Head Gasket Feb 08 $ 105.00
ARP Head Bolts Feb 08 $ 115.00
Head Gasket Set Feb 08 $ 223.05
Power steering Hoses Feb 08 $ 25.00
Thermostat Feb 08 $ 7.00
Rebuilt Cylinder Head Jan 07 $ 525.00
Fuel Injector Seals Jan 07 $ 35.04
Timing Belt Jan 07 $ 50.48
Timing Cover Seal Set Jan 07 $ 26.60
Valve Cover Gasket set Jan 07 $ 24.00
Heater Hoses Jan 07 $ 134.67
Spark Plugs Jan 07 $ 18.60
Total Wheel Alignment Jan 07 $ 60.00
Front Sway Bar Jan 07 $ 165.69
Front Sway Bar Link Jan 07 $ 60.78
Front Struts Jan 07 $ 78.27
Rear Struts Jan 07 $ 78.27
Front Brake Rotors Jan 07 $ 156.74
Brake Pads Jan 07 $ 20.18
Rear Brake Rotors and Brakes Jan 07 $ 151.88
Rear Brake Pads Jan 07 $ 17.97
Lower Ball Joints Jan 07 $ 118.56
Parts Total $4334.04
  • Engine Rebuild @ Approx 167k $ 2000
Total After Engine Build ( minus Labor ) $ 6334.04
Approx 10K since motor rebuild and 1000 Miles on recent Head Work.
So i got this for a pretty good deal, there were reciepts and everything. When i got the car everything was fine, but than i let one of my friends test drive it, he made sharp ass u turn and my wheels spun out and we basically drifted sideways left to right and he was about to crash my fcking brand amazing ass supra into the pole but he got control again. than after maybe about 10 mins i started hearing a rattling noise everytime you past about 3000 rpm. So i brought the car back to my house and reved the engine and it sounds horrible, before 3000 its fine but after than its just a bunch of rattling. CAN anybody tell me what this is? Possible when he spun out my wheels he couldve snaped something or possible made something loose? I was going to take it to the shop but i dont want them telling me a bunch of bullshit so i wanted to see if anyone on here had the same problem as i. thanks
89MkiiiSupra is offline   Reply With Quote
Old 08-16-2008, 06:30 PM   #2
mkiiisupra
Not sure but i am curious as to why it needed the head redone after only 9k miles on a fresh rebuild.
1990 Toyota Supra Turbo A/T
Old 08-17-2008, 05:09 AM   #3
azerty
azerty's Avatar
azerty is on a distinguished road
Do you have any codes?
Is it chocking and dies after 3.000 rpm?
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 08-17-2008, 06:50 AM   #4
SideWinderGX
rodknock? spun a bearing? turbo might be shot too, the 'death whine'.
my car:
Old 08-19-2008, 03:49 AM   #5
89MkiiiSupra
took it to the shop and said it was rod knocking. i was hela fcking pissed but my friend is going to cover everything so i aint tripping. the people said might as well replace the engine because the price is the same due to labor of fixing the rod knock becuhz of the burnt bearings
Old 08-20-2008, 03:53 AM   #6
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
what is this death whine you speak of?
tak2099 is offline   Reply With Quote
Potentially buying 1987 Supra Turbo with knocking noise saturnvii7 MKIII Supra 3 04-24-2007 05:59 PM
Help with wierd noise SupraSaver87 Non-Generation Specific Questions 5 07-06-2006 12:10 AM
RATTALING NOISE AT 3000 rpm!! jaysun MKIII Supra 7 05-03-2006 01:51 PM
