Old 08-07-2008, 01:39 AM   #1
twinturbolvr
twinturbolvr is on a distinguished road
Default Running Too Hot!!!!!
i have a new JDM 7m_GTE fresh off the presses with 5,000 miles on it, new sensors, new thermosat, new water pump, hoses all good, no leaks, i put redline water wetter in the coolant, only 5-7 psi, but im still running 1/2 to 3/4 on temp. i lust for the supra but i dont want to drive it im scared im gonna do damage if i drive it. please help!!!!!,
twinturbolvr is offline   Reply With Quote
Old 08-07-2008, 02:17 AM   #2
dcrusupra
dcrusupra's Avatar
Radiator clogged? Do you have a fan shroud? And have you done a block test to see if the headgasket went?
What do you mean by new? The engine just came from Japan or you had it rebuilt 5k miles ago?
New Rebuild
My CarDomain
Old 08-07-2008, 11:46 AM   #3
twinturbolvr
Question running 2 hot!!!!!!
i got the car from a friend he spent 3500 on a rebuilt 7mgte engine. its got 5k on the engine since put in the car. i have a fan shroud, the car has been not driven often so a clog in the rad could be, can you unclog one? or just replace it? thanks a lot....chris
MKIV Supra TT Daytime Running Lights?? MIX MKIV Supra 2 08-30-2007 02:52 AM
Running Sooooooo Rich! Help! godgaveussid MKIII Supra 4 08-29-2007 08:46 PM
Running very rich OmeGa MKIII Supra 3 12-09-2006 09:59 PM
supra running rough finn MKIII Supra 0 09-25-2006 07:10 PM
fixed the running rich problem djalkyd MKIII Supra 6 05-04-2006 04:31 AM
