Old 07-30-2008, 07:52 PM   #1
skatecboy45
skatecboy45 is on a distinguished road
Question Cooling system Oddity
I found a coolant leak in the back of the engine compartment near the block, and found that it was some sort of Cap that was clamped on with a hose clamp. It was old and had holes in it and I was wondering if this is Facory, or if someone just stuck it there because they took something off.
skatecboy45 is offline   Reply With Quote
Old 07-30-2008, 08:21 PM   #2
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Talking
i'm assuming you have a non-turbo. my 87 non-turbo had the same thing. go to a dealership to get a new cap. the only problem is finding the part number. you've got to explain what it is your looking for and then scan thru the pics with the guy at the part counter. at least that what i had to do.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 07-30-2008, 08:31 PM   #3
skatecboy45
87 turbo, but okay thanks.
Old 07-30-2008, 08:49 PM   #4
robertsws
robertsws's Avatar
ok, well same thing i guess, on my 87 i had the same problem and i thought the same thing, that some idiot had capped something off, but i went to the dealership and got a replacement, so it is a stock part on the 87 at least.
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
Old 07-30-2008, 09:38 PM   #5
azerty
azerty's Avatar
azerty is on a distinguished road
Some pictures would help...
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
high pressure in cooling system jarekt Non-Generation Specific Questions 3 09-01-2007 06:39 PM
burping the cooling system from air bubbles suprra_girl MKIII FAQ 2 04-19-2007 05:40 AM
Cooling system question thunder550 MKII Supra 8 12-17-2006 12:53 PM
Cooling system problem vancouver874 Non-Generation Specific Questions 2 07-17-2006 03:43 PM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
