Old 07-12-2008, 05:30 AM   #1
azerty
azerty's Avatar
azerty is on a distinguished road
Default getting to the crankshaft
Hi.
I began to take down the engine from my supra, in the quest to put some new bearings on the crankshaft and do some mahining on it.
Along the way are ome gaskets....
So my question is that: What gaskets should I use. Do you know of a brand that has quality qaskets? Or are the stock ok?
And I am not talking here about the HG. That is a well studied matter.
I am talking about the gasket to the oxigen sensor for example.
Any advice for the way?
Thanks.
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 07-12-2008, 07:37 AM   #2
supramacist
supramacist's Avatar
If you only need a handful of gaskets.
Go to the dealership.
That way you can just get the ones required instead of a kit that has a bunch of crap gaskets that you won't use all of.
Stay away from those cardboard paper gaskets.
Permatex copper coating is the shizzle also. Coat the gaskets with that front and back. You'll blow a new hg before those bad boys give way.
So long as you don't get any solvent type liquids on them.
And if you do. No worries because you used oem replacement parts from the dealership.
Old 07-12-2008, 05:29 PM   #3
toneloc87 2
toneloc87 2's Avatar
toneloc87 2 is on a distinguished road
Fel pro gaskets are pretty good
toneloc87 2 is offline   Reply With Quote
Old 07-12-2008, 10:25 PM   #4
supramacist
How can you say felpro are good gaskets when for 12$ you can get the entire upper intake set for 12$????
They'll work if you use permatex copper.
You guys need to learn to go with toyota OEM and except no substitutes.
Unless you do you will never get off these forums to actually DRIVE your car.
Old 07-17-2008, 09:33 AM   #5
azerty
azerty's Avatar
So... I was thinking to get my intercooler cleaned up as well, but I have a problem... I don`t know how to get it out of the engine bay.
I looked it up in the TSRM but I haven`t find anything on this subject. Can anyone help me?
Also, do you know if there are aftermarket intercooler hoses out there for our cars?
Thanks.
HKS ssqv bov
boost gauge
K&N FIPK
550cc RC Injectors
Aeromotive FPR
Old 07-17-2008, 08:00 PM   #6
Bill UK
AEM EMS
Bill UK's Avatar
Don’t forget to have that crankshaft crack tested before any regrind, especially if you had a shell spin. Some info here for intercooler cleaning/removal.
Old 07-17-2008, 11:37 PM   #7
mkiiisupra
Toyota Supra MK3 Aluminum Shafts : Shaftmasters, Quality Parts and Service at a Great Price
TOYOTA - LEXUS - COOLEEZE
Good quality pipes for hte stock intercooler set up, long delay though
1990 Toyota Supra Turbo A/T
Old 07-30-2008, 10:30 PM   #8
azerty
azerty's Avatar
Sooo...
The engine is out, the transmision as well.
So I have looked at the clutch and I idn`t like what I saw.
It has to go, so I an thinking a new racing clutch, and maybe a light weight flyweel.
The question is witch one would you recomend?
What make and what model.
Did you get one? How was it for you?
What should I change also at this time?
Thanks.
HKS ssqv bov
boost gauge
K&N FIPK
550cc RC Injectors
Aeromotive FPR
Old 08-07-2008, 01:17 PM   #9
azerty
azerty's Avatar
OK...
Can someone please tell me what these are?
Thanks.
HKS ssqv bov
boost gauge
K&N FIPK
550cc RC Injectors
Aeromotive FPR
Old 08-07-2008, 01:33 PM   #10
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
I believe one is for egr and the other is for the fuel pressure regulator.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
Greddy e-01 boost controller
245's all around
Slotted + drilled all around
3" straight piping turbo-back, 4" tip
Lowering springs
HKS mushroom air filter
paulmicin is offline   Reply With Quote
Locking the Crankshaft go.stfu MKIII Supra 4 07-14-2007 02:41 PM
crankshaft!!? ethan12510 MKIII Supra 6 04-07-2007 06:44 AM
