Old 07-08-2008, 02:53 AM   #1
Starlight1988
Starlight1988's Avatar
Starlight1988 is on a distinguished road
Default Increasing the Redline
Sup! i was just wondering if anyone knew how to increase the engine's redline. i know someone told me something about tuning the ECU and wanted to know if that was it.
zoom zoom!
Starlight1988 is offline   Reply With Quote
Old 07-08-2008, 05:55 AM   #2
SideWinderGX
SideWinderGX is on a distinguished road
New valvetrain is needed i believe. not sure on the stock rpm limits for the block components though.
afaik, the rev limiter is only imposed because there is no mapping for the injectors to fire any faster. map the injectors up to a certain speed and theyll fire up to that certain speed. how to do that, i cant help ya
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
Old 07-08-2008, 03:50 PM   #3
robertsws
robertsws's Avatar
robertsws is on a distinguished road
i was told a few months ago that you needed to upgrade the pistons as well. not sure if that's the case or not but it does raise a question about the rpm limits / tolerances of stock components
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 07-08-2008, 04:10 PM   #4
Chambers
Chambers's Avatar
I would say you need all new connecting rods and pistons for the bottom end, the stock connecting rods may give out at higher rpms.
As for the valvetrain, you would need stronger valvesprings so they will adquetly close so they do not hit the pistons, then you would problably need to replace all the other valvetrain componetns as well.
I did read somewhere, that there was someone who would take Toyota ECUs and "tune" them for a higher rev limit and fuel maps, but you can do that with a piggback ECU as well.
You would have to lay down some serious cash to do this, but in the end you would have one reving mo-fo.
"Stuck in the 80's"
Old 07-08-2008, 07:22 PM   #5
SideWinderGX
in the long run....what i want
my car:
Old 07-10-2008, 11:03 PM   #6
supradrift
supradrift is on a distinguished road
they put redline on cars cause thats the farthest they can rev safely on stock components without putting to much strain on other parts id leave it til some serious building is done and your sure everything can handle it
supradrift is offline   Reply With Quote
Old 07-10-2008, 11:13 PM   #7
SideWinderGX
Thanks.
my car:
engine wont redline? merryprankster MKIII Supra 7 06-23-2007 04:00 AM
increasing steering angle? thechori MKIII Supra 1 10-09-2006 06:57 PM
type of oil you run on HEMAN MKIII Supra 11 08-22-2006 05:18 AM
Redline Problem cars4me89 MKIII Supra 27 07-27-2006 04:02 AM
what's the name of that supra redline 3 song? jeetee-ess Off Topic Forum 2 01-12-2006 10:59 PM
