Old 07-13-2008, 10:21 PM   #41
Canuckrz
Canuckrz's Avatar
Canuckrz is on a distinguished road
Yeah I think it might be just a coincidence, so I think I might need a new starter as well because it too about 15 tries before it would start to turn over.
I'll get Toyota to do a leak down and pressure test tomorrow.
So I take it we're back to thinking its the rings are the problem?
Canuckrz is offline   Reply With Quote
Old 07-13-2008, 11:33 PM   #42
Busted Knuckles
Busted Knuckles's Avatar
If the turbo has been ruled out, and the amount of oil we are talking, then yes, I think it is the rings.
Old 07-13-2008, 11:36 PM   #43
Canuckrz
Canuckrz's Avatar
Well the turbo creates boost how well its working remains to be seen, is there any guides on how to get at that intercooler so I can see if there is any oil in it? Its pretty far down there and it looks like I'd have to take off the front fascia to get a good look at it.
Old 07-13-2008, 11:41 PM   #44
supramacist
supramacist's Avatar
The intercooler is going to be so mucked up on the inside that you're going to have to clean the hell out of it and put it back together and drive it a bit before you can tell.
If every time you throttle it hard you get white smoke. That's a good indicator that it could be the rings. But it's also not exact as it could be a few things.
Old 07-13-2008, 11:45 PM   #45
Canuckrz
Canuckrz's Avatar
I've got no problem with cleaning it, if anything I'd welcome it because I'm getting shit mileage right now and anything that helps is worth it.
Just tell me how to get at the thing
Old 07-14-2008, 12:20 AM   #46
supramacist
Ihatehacks
He wrote up a thread a long time ago about the entire process.
I'm an n/a. So I can't just go out and have a look see. But if you can track down the thread. He explains it quite well.
He said it was a huge mess and not real easy to do. Cleaning it should help you alot.
Aside from that you should use your tsrm. If you don't have one let me know and I'll send you a link.
Old 07-14-2008, 12:24 AM   #47
Canuckrz
Canuckrz's Avatar
You mean this thing? Does it show how to get at the intercooler or how to clean it?
MK3 TSRM On-Line
Old 07-14-2008, 12:33 AM   #48
Canuckrz
Canuckrz's Avatar
I tried searching his name and nothing about the intercooler came up, and I tried searching intercooler but there are hundreds of threads. What should I search for to find it?
Old 07-14-2008, 01:36 AM   #49
supramacist
Jeez it was so long ago.
I'll look and see if i can remember which 1 it is.
The tsrm should show you what you need to know.
Old 07-14-2008, 09:34 PM   #50
Canuckrz
Canuckrz's Avatar
Alright shes at toyota getting a compression test done, should get the results back tomorrow. They didn't have the tools to do a leak down test unfortunately.
Any luck finding that thread supramacist?
