Old 07-04-2008, 05:46 PM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Default injector question
does anyone know if there is a way to see what injectors i have. i'm not sure if the last owner upgraded the injectors or not but it is a possibilty.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
Old 07-04-2008, 06:31 PM   #2
Chambers
Chambers's Avatar
I think stock turbo injectors have black plugs/tops, at least thats the color my turbo injectors are.
"Stuck in the 80's"
Old 07-04-2008, 07:57 PM   #3
toneloc87 2
toneloc87 2's Avatar
toneloc87 2 is on a distinguished road
well you can look at the injector clips and if they are any color then grey and brown then they are aftermarket. usally you have to change the clips to put new injectors in
toneloc87 2 is offline   Reply With Quote
Old 07-04-2008, 11:44 PM   #4
will fight for food
will fight for food's Avatar
will fight for food is on a distinguished road
what are some good injects to upgrade to i have herd a lot of bad things about the drop in venom injectors so witch ones are good and are 550cc's good or should i go 680cc there is some much i dont know should have bought i supra long ago
87 supra 7mgte 3" exhaust
used to be a honda guy but now all about the supra
will fight for food is offline   Reply With Quote
Old 07-05-2008, 02:54 AM   #5
toneloc87 2
go 550 and lexus afm. im using RC 550s with a LIPP lexus afm replica
Old 07-05-2008, 03:54 PM   #6
robertsws
robertsws's Avatar
rc ebgineering 550cc injectors are best and deffinately the lexas AFM. be sure to upgrade your fuel pump as well, the walbro 255lph and an aeromotive fuel pressure regulator would be wise.
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
ARP bolts w/MHG
power steering pump
