Old 07-02-2008, 04:30 AM   #1
sd88supra
sd88supra is on a distinguished road
Unhappy tell me its a bhg
... because I have no idea what else it could be. No milky oil, no white smoke, no power loss... but it does spit coolant out of the reservoir. Given that mine is a N/A, I first thought it was trapped air that pressurized as the temperature increased. So I burped it- several times. I had no idea where air could leak in through other than a bhg, so I stopped driving it.
I'm just about ready to start tearing the head apart, I just need to finish reading the various bhg posts. I just hope the surface isn't warped. I'm thinking stock gasket with ARP bolts. I don't want to have a shop do it because they'll set it to factory specs. Any input is appreciated.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 07-02-2008, 07:26 AM   #2
CyFi6
That is a very common sign of a BHG. Get a leakage tester and pressurize each cylinder on tdc compression with the radiator cap off, if the coolant level changes at all or bubbles when you pressurize any cylinder, you can be sure it is a bhg or cracked head/block, but more likely head gasket. After a drive, is the upper radiator hose full of air as well? Good sign of a bhg.
Old 07-02-2008, 08:25 AM   #3
supramacist
supramacist's Avatar
ARP studs..., not bolts and forget about the oem hg and get the head decked and put an MHG on it.
Bolts give, where studs do not.
Whatever you do for an hg is going to be problematic if you don't at minimum lap the block and deck the head.
Old 07-02-2008, 09:09 AM   #4
edmonton
edmonton's Avatar
edmonton is on a distinguished road
could be intake manifold gasket, i just had both mine replaced but it was pretty obvious that was the problem cos i could hear a vacuum leak.
White 1989 5sp Turbo Targa
shimmy wastegate 3 washers, 3" exhaust 2 1/2" piping, raised hood 24mm, R1 diamond drilled/slotted rotors
Momo short shifter, White Glow Gauges
Panasonic CQ-C7105U MP3/CD deck, 2x12" Rockford Fosgate HE2 subs, Pioneer GM-X922 amp
edmonton is offline   Reply With Quote
Old 07-02-2008, 05:37 PM   #5
CyFi6
having the head milled, the block checked and cleaned well, you can use a stock head gasket with your old oem bolts, or new ones, or arp bolts or studs, it really doesn't matter very much. Just inspect your old bolts for stretching or pitting before you re-use them. If you are keeping your supra to stock power levels, i don't see why you would have to go all out if you are on a budget. And make sure you do not try to go metal head gasket unless you completely do the job 100% right, its not something you can half ass.
Old 07-02-2008, 09:14 PM   #6
supramacist
Order the ARP product manuals and research them.
Even they say the studs have better grip because the studs don't turn..., only the nut where as the entire bolt turns.
Old 07-03-2008, 01:51 AM   #7
ddmcse
ddmcse's Avatar
Cool
studs are more work
it's hard enough to lower the head onto the 2 register pins w/o scratching it a little
F that your supra is an N/A and you won't be boosting it .you got it right go for it and torque it right
you're going to have the head checked for flat ? or you going to check that yourself ?
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 07-03-2008, 04:04 AM   #8
supramacist
Studs are just so damn pretty.
Grip was my word. I was trying to say what ben said.
Without actually saying it. Or thinking it rather.
ARP also states the 70lbs is the torque spec.
Old 07-03-2008, 06:40 AM   #9
sd88supra
I'm contemplating taking it to a mechanic friend (he lives kinda far though), because at least he'll torque it to 75 ftlbs or 101 nm (why doesn't anyone get the units right?), and hes changed countless headgaskets, so he'll do the proper machining. I, on the other hand have never done more than tune ups so I don't know if I'll end up doing it myself.
Do I really need a metal gasket? My car's an N/A. I was under the impression that an oem with ARP studs was the way to go. But it seems that even the oem bolts (new of course) will work well with an N/A if torqued properly.
Old 07-03-2008, 09:20 AM   #10
CyFi6
You dont even need new oem bolts if yours are fine. They are not considered a replacement part, in this engine at least.
