Old 06-17-2008, 04:36 AM   #1
magikl1
magikl1 is on a distinguished road
Default 1JZ 1990 Dies when pushing in clutch????
Hello,
I just bought this car and I want to fix it so that it is driveable, any ideas? I am new to the scene, been a domestic driver for way to long. Any help?
Thanks
82,352 Miles, Engine is very strong, runs great. IAC?
I searched forum, couldn't find any definitive answer, I haven't check codes yet, buddy has scanner right now.
magikl1 is offline   Reply With Quote
Old 06-26-2008, 03:22 AM   #2
stevenr816
stevenr816 is on a distinguished road
Originally Posted by magikl1 View Post
Hello,
Thanks
so you can start it up and rev it up normally and runs fine, but once you push the clutch in it dies?
ive heard of this before, its usually your thrust washers and called crank walk. you push the clutch in, pushes the crankshaft forward and temporarily seizes the engine until you let the clutch out.
do you have an aftermarket clutch on this? ive only heard of 7m's doing this with like a spec stage 3+
steven
stevenr816 is offline   Reply With Quote
Old 06-26-2008, 02:59 PM   #3
supradaddy0803
supradaddy0803's Avatar
Ok for one 1JZ's are not notorious for crank walk that is the 4G63. It has a three piece thrust main bearing and it comes apart. Well for some background who did the 1JZ swap, have you checked the wiring to make sure it is correct. Also you can check, when you start to push the clutch in slowly, does it die instantly or does it start to slow then die as you get closer to fully depressed. If not then that rules out the crank walk thing just for shits and giggles. When you bought the car did the guy say it was ever running right? This would lead me to believe that he messed up the wiring when he did the swap and you will have a rewire headache ahead of you. There are some other things to check but check the things I have told you first and then get back to me with the result.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
