Old 06-09-2008, 08:13 PM   #1
burton51m
burton51m's Avatar
Default what connector is this??
Im putting everything back together after replacing my headgasket and i cant find out where a connector on the wiring harness goes to. It's right by tranny fluid dipstick on the right side of the motor. The connector is right next to two other big round connectors for the neutral safety start and reverse lights.
here are some pics from the top
From the bottom...
Old 06-10-2008, 01:40 PM   #2
supradaddy0803
supradaddy0803's Avatar
All I can say is look around for a plug that matches it. It is pretty far back there to be anything to do with A/C or much of anything unless you have that part of the harness loomed wrong then it may be in the wrong place.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-10-2008, 02:34 PM   #3
burton51m
burton51m's Avatar
Ya, I Looked around for the plug that matches it for 2 hrs yesterday. I have it in the right place i know that.
i guess ill keep wedging my hand inbetween parts of the motor until i can find a place for it. Not fun.
Old 06-10-2008, 03:03 PM   #4
TomFraser
TomFraser is on a distinguished road
on a N/A 88 there are 2 connectors that are unhooked... the same that are in your pictures... I do not know what they do, however mine aren't connected either
TomFraser is offline   Reply With Quote
Old 06-11-2008, 03:07 PM   #5
burton51m
burton51m's Avatar
I was doing some searching and found out that connector might be used for manual transmission cars. mine is automatic so i hope that is what it is.
Old 06-12-2008, 01:55 AM   #6
supramacist
supramacist's Avatar
Ya this question pops up every 90 days or so with the same darn pic.
You don't use that connect.
Old 06-12-2008, 02:03 AM   #7
TomFraser
just curious... why is it there? for testing equipment purposes?
Old 06-12-2008, 04:03 AM   #8
supramacist
I have no idea.
All I know is that mine has no connect either.
Nor does anyone else that I know.
May be it's an automatic tranny thing.
Your guess is as good as anyone elses.
Old 06-12-2008, 05:05 AM   #9
burton51m
burton51m's Avatar
Ya, i'm pretty sure its the clutch switch for manual transmissions.
Old 06-13-2008, 12:28 PM   #10
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
That is the connector for the abs speed sensor on the end of the tranny.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
Greddy e-01 boost controller
245's all around
Slotted + drilled all around
3" straight piping turbo-back, 4" tip
Lowering springs
HKS mushroom air filter
paulmicin is offline   Reply With Quote
