Old 06-06-2008, 09:37 PM   #1
SephyraTigre
SephyraTigre is on a distinguished road
Question What is the proper engine oil weight range for the 7m-gte?
I have the 7m-gte engine and it has approximately 104000 miles on it and has been rebuilt and head gasket replaced. I recently purchased the vehicle and don't know what is the best oil for this vehicle. I went down to the local Toyota shop and asked for the correct oil for my vehicle and bought it. When I returned and actually looked at the bottle it said Toyota brand 5w-20. It says it's made for Toyota engines and has been approved for turbocharged engines. Well that seemed a little odd to me so I haven't changed it, I do have a Toyota oil filter that will replace the fram that's in there.
I did some reading and appearantly it is a fairly new type of oil? And appearantly most(some/all?) newer vehicles use the new 0w-20 and 5-20 blends as recommended by the manufacturer? Well anyways, the little gif image available from this handbook link ( MK3 TSRM On-Line ) is a little too blurry so can anybody tell me what they suggest I use? Does it say 10w-30 in the middle band? Oil brand? High mileage oil? Synthetic? I live roughly 2000 ft above see level and the climate is going to be from cool (50 degrees Fahrenheit) to hot (maybe up too 100 degrees max but you never know..) Um I think that should be most of the details, help is greatly appreciated as I would really like to change the oil and treat this car right. =D
Live in love, never in fear. 1990 MKIII 5-speed manual, 7M-GTE.
SephyraTigre is offline   Reply With Quote
Old 06-07-2008, 03:14 AM   #2
I live in Denver, similar temp variations. I usually run 10W-30 up until early summer and then switch to 10W-40. Depends on how hard you're going to be running the car and how well your cooling system is doing it's job.
I used to run Castrol GTX High Mileage, but now that most of the engine's rebuilt and all of my seals are new I run a synthetic blend.
Old 06-07-2008, 04:04 AM   #3
azerty
azerty's Avatar
azerty is on a distinguished road
Hi.
I am using Motul 300V competition, full synthetic, competition oil. It is a 15W50, above existing standards.
With it you should be carefull not to WOT till the engine is at normal operation temperature, but after that.... WooOt.
I used to run on semisynthethic oil (10W40) or somethingm and I was putting almost 1/2 l oil for 1 l gas , not to say it ruined my crankshaft bearings.
but this is just me.
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Old 06-07-2008, 07:06 AM   #4
There's a lot more wrong with your car than just the oil weight...
Toyota only recommends 20W-50 for the HOTTEST environments for a reason... I'm not going to get into this here though. There's a TON of info on oil and what weights fit your needs the best over at supramania.com.
Old 07-01-2008, 01:26 PM   #5
shiftysupra
shiftysupra's Avatar
Well, if you live somewhere cold I would use the 5w-20 remember (ei. 10W is the thickness when you pour the oil, or in your case 5W, and the 20 is the molecular strength of the oil.
Old 07-04-2008, 08:12 AM   #6
mkiiisupra
Alot of very wrong things have been stated.... about oil here.....
Please read before you do something stupid
Motor Oil
1990 Toyota Supra Turbo A/T
Old 07-04-2008, 04:48 PM   #7
toneloc87 2
toneloc87 2's Avatar
toneloc87 2 is on a distinguished road
wow that answered alot of questions i had and i feel like i know everthing there is know about oil
toneloc87 2 is offline   Reply With Quote
Old 07-05-2008, 01:58 AM   #8
shiftysupra
Thanks mkiiisupra for clearing everything up
Supra engine and tranny weight boogum7 MKIII Supra 2 02-14-2006 11:56 PM
