Old 05-30-2008, 04:06 PM   #11
supradaddy0803
supradaddy0803's Avatar
Man do like I did and buy a one peice one they are so much easier to put in and take out. Unless you dont have a turbo then you may have a hard time finding one for a W58 and not the R154 like most of them are made for. As for your brakes dragging I would take a look at how everything is set on the rotors themselves. See if when the wheels are in the air if the rotors turn smooth or if they make the grinding noise. You may also need to check your wheel bearings, if they have play in them then it may be grinding when you have weight on them. Mine were like that and it sucks doing them as well but well worht the effort.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 05-31-2008, 02:47 AM   #12
Chambers
Chambers's Avatar
Few days ago the center carrier bearing finally blew in my car, luckily I was only 1/4 mile from home, it was knocking away. lol. I dropped the drive shafts and took it to a local welding shop to get a one piece made. They did a exceptional job on it, the machine work and the welds were awesome! In the end they only charged me $200. I just took it for a spin and I can say it felt like a lot more power was being put to the ground, but it could also just be that I was driving my slow 84 Ranger for the past week, lol. Either way, I'm very happy with the one piece.
"Stuck in the 80's"
Old 05-31-2008, 01:12 PM   #13
supramacist
supramacist's Avatar
Awesome deal they cut you on that shaft.
If you have to take the shaft...., I'd say you took it like a man .
200$ is less than toyota wants for a new carrier bearing.
Old 05-31-2008, 07:15 PM   #14
spudz29212MKIII
spudz29212MKIII's Avatar
spudz29212MKIII is on a distinguished road
thats what im doing getting a one peice lightweight shaft. gotta get some supports thou dont want to rip out yoke with large ass torque.
Wheel bearings are fine, the brakes are just binding not releasing completely maybe nasty fluid in the lines, boiled over, or idiot put powersteering in the res. before i bought it.
Anyways all rubber in system swelled up and seals went to shit.
New Master Cylinder, new rotors, new pads, new calipers, and new lines that im putting in today. With each replacement the binding became less and less so im pretty sure its the lines. After a good gravity bleed then a two man bleed Im good to go
Zach
spudz29212MKIII is offline   Reply With Quote
Crank Shaft Pully Question kidsusukigsxr Non-Generation Specific Questions 1 04-15-2011 08:45 PM
Brake question suprabahamut MKIII Supra 4 08-13-2008 05:32 AM
anti-lock brake system abs question linuxgurupodboy Non-Generation Specific Questions 0 09-30-2007 03:06 AM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
brake question damdog05 MKIII Supra 13 07-18-2006 04:01 AM
