Old 05-12-2008, 12:27 AM   #1
mastergrader007
mastergrader007 is on a distinguished road
Default b.o.v. problem???
Hi,
I just bought an 88 supra turbo from a friend with the JDM 7mgte engine. it is all stock and running strong. my question is, i had shimmed the wastegate and than realized i couldnt hear the b.o.v. when i shifted gears. this made me nervous so i took out the shims but i still can't hear it let the pressure go. is this normal?? i have never owned a turbo before and im a little nervous. also, how far should the needle go on the boost gauge?? as in PSI? just wanna make sure everything is working proper.. thanks
OH, forgot to mention, my gauge goes from -2 up to +4 mmhg (whatever that means)! and my boost is half way between 0 and +4 at best
please help me!!!
mastergrader007 is offline   Reply With Quote
Old 05-12-2008, 04:05 PM   #2
mastergrader007
Default anybody use this site?
Hello,
Just wondering if anyone here uses this site??? where is everyone??? i have a problem and im looking for some help here please
Old 05-12-2008, 07:49 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
First of all you shouldn’t hear the Bov vent, the supra is fitted with a recirculating Bov and doesn’t vent to atmosphere, to test the stock Bov;remove it from the car and blow down the main large ? hole, you shouldn’t be able to feel any air passing through to the other large ? hole. (You will need to establish if you have a stock Bov first)
Not sure of the stock psi mine goes to the max on the stock gauge, and 10 psi on my extra boost gauge. The only mods are shimmed wastegate (3 washers) and front cat removed. If I remove the second cat the boost goes up to 14 psi and I hits fuel cut-out.
Old 05-12-2008, 10:09 PM   #4
mastergrader007
Default thank you
thank you very much for your help. i was beginning to think that this forum was a ghost town or something. lol. yes its a stock bov and i guess i can re-shim my wastegate then! awesome. thanks again
Blake
ps. i just bought this supra and there is no exhaust on it yet. would this cause a lack of boost pressure??
Old 06-29-2008, 05:02 PM   #5
edmonton
edmonton's Avatar
edmonton is on a distinguished road
is it possible to buy an aftermarket bov that vents to atmosphere then maybe just plug the hole where the stock bov recirculates too?
White 1989 5sp Turbo Targa
shimmy wastegate 3 washers, 3" exhaust 2 1/2" piping, raised hood 24mm, R1 diamond drilled/slotted rotors
Momo short shifter, White Glow Gauges
Panasonic CQ-C7105U MP3/CD deck, 2x12" Rockford Fosgate HE2 subs, Pioneer GM-X922 amp
edmonton is offline   Reply With Quote
Old 06-30-2008, 02:59 AM   #6
SideWinderGX
SideWinderGX is on a distinguished road
While this would technically work, the supra meters *all* the air that enters the engine. When air is released when you shift and vented to the atmosphere, the engine thinks its still in the engine...which will cause it to run very rich. the car will still run, but not as well.
my car:
1987 brownish Toyota Supra Turbo, automatic 7MGTE engine with ~100k miles on it.
SideWinderGX is offline   Reply With Quote
Old 06-30-2008, 05:51 AM   #7
edmonton
edmonton's Avatar
then would you have to buy a computer to tune the air/fuel mixture or is the vented air so small it doesn't matter? what have other people done that added after market blow off valves? thanks
Old 10-20-2009, 03:06 AM   #8
dupra87
dupra87 is on a distinguished road
Default reply
i have just done the same thing. but i bought a cheap one. bad choice. spend the money and get a good one. my car dies if i dont have the pressure all the way on. its like i dont even have it. so in short dont be cheap buy a nice one
dupra87 is offline   Reply With Quote
Old 10-20-2009, 03:30 AM   #9
Some people suck it up that a BOV is going to screw up their performance between shifts, others buys a piggyback that will allow them to tune for it and others buy a BPV or a BOV with a BPV attachment (BPV = bypass valve, these are the ones which, like the stocker, dump back into the intake).
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
