Old 05-03-2008, 05:10 AM   #1
3.0trd
3.0trd is on a distinguished road
Default woe is turning!!!
(89 na manual)well, no questions about the motor this time, now its the power steering. Going straight is fine, merging is fine, but as far as turning more than a few degrees? talk about scarry... Whenever I need to make a sharp turn, low or high speed, the power steering fights me like crazy, and almost wont turn, but it only happens on the initial turn in, once it gets past a certain point, it goes really loose and no more problem, but diving into corners sucks cause when it goes loose changes... I was wondering if there are any common problems with the mk3 power steering system. I know some sports cars computers stiffen up power steering at high speeds to decrease the chance of oversteering(merging and whatnot) does the mk3 have that? my pump sounds fine, and I've flushed the system completely. I'm thinking the rack itself may be bad, any opinions?
3.0trd is offline   Reply With Quote
Old 05-03-2008, 08:09 AM   #2
Fredde
Fredde is on a distinguished road
Hi.
Check the belt to the steeringpump, sounds to me like it is slipping.
/Fredrik
Fredde is offline   Reply With Quote
Old 05-03-2008, 04:52 PM   #3
3.0trd
I don't hear any squealing, checked the tension, and inspected it, seems fine to me. took it off and spun the pump pulley, no grinding, binding, or wobbling.
Cometic MHG, ARP studs, H&R lowering springs
Old 05-04-2008, 02:36 AM   #4
mrnickleye
mrnickleye's Avatar
Sounds like the rack. Not hard to change. No computer controls for steering.
Old 05-04-2008, 04:34 AM   #5
3.0trd
I'm thinking the rack too, just sucks cause they are like $300!
Turning Signals 5upra lov3r MKIII Supra 4 11-02-2008 07:22 AM
86 NA dies/idles low when turning the steering wheel tty MKIII Supra 8 10-30-2008 07:46 PM
Whining while turning mr.w MKIII Supra 7 09-04-2007 04:07 AM
