Old 05-02-2008, 06:17 AM   #1
slader99
slader99 is on a distinguished road
Default Egr Cooler, Coolent Banjo
Hey all,
First of, thanks for all the help thus far. Got the old supra back up and running after replacing the problem rod bearing. Runs like a top, no CEL!.
As for my problem, I seem to be loosing coolent out the rear of the engine. I've narrowed it down to either the EGR cooler cover, or the Banjo fitting that splits the coolent at the rear of the engine. Shit is cramped back there and I cant tell for sure where its comming from. I replaced the egr cooler gasket, cleaned the faces real well AND used silicon. I also tightened the banjo fitting real well with fresh gaskets. I can say for sure that the hoses & clamps are fine, Ive re-evaluated them and tightened them.
The leak isn't hudge, or at least it didn't seem hudge when the engine was up to temp, perhaps it will be more of a torrent when I start it cold.....
Has anyone got any good ideas regarding tightining the EGR cover while the head is on and engine in the car? Perhaps some special tool or method. Can it even be done?
Thanks for any help,
Cheers,
Colin Slade
slader99 is offline   Reply With Quote
Old 05-02-2008, 10:28 AM   #2
Cool
all but the bottom ones
mirror and a small box end wrench . i learned the hard way on that cover myself .
"make sure it's tight before you put the head back on "
Old 05-02-2008, 11:57 AM   #3
f00g00
Default piping behind block
Did you check the piping behind the block? One side is the heater hose and the opposite side is the rubber plug that gets overlooked. The engineers designed the piping to work on LHD or RHD cars so you only have to switch the rubber plug and heater hose around depending on the config of the car.
Old 05-02-2008, 02:17 PM   #4
There is NO coolant in the EGR cooler ! Only EGR gasses. So.........it NOT that !
Hoses or hose fitting is the likely problem. Hope it not the headgasket.
Old 05-02-2008, 04:11 PM   #5
slader99
Well that certainly narrows the search down. It seemed like the top of the EGR cooler gasket was wet, but if no coolant passes within that cover, I guess I can narrow the problem down to the coolent banjo at the rear of the head.
Can anyone confirm?
Thanks,
Colin Slade
Old 05-02-2008, 06:18 PM   #6
supramacist
supramacist's Avatar
Check the coolant hose right behind the rear of the spark plug galley.
There's another coolant hose that runs to the back side of the block right around the starter.
Hope this helps.
Old 05-02-2008, 06:20 PM   #7
azerty
azerty's Avatar
azerty is on a distinguished road
I had problems with that hose to the rear of the engine.
It snapped.
Looking to it from above, didn`t looked broke. I even tryed to tide up the clamp there, but no result.
I eventually took it out of there and it was all coocked up. It broke to pieces when coming out of the engine in 100 pieces.
Just replace it with any hose designed for the coolant system.
Cheap and easy fix.
Good luck.
1988 yelow manual turbo targa
HKS ssqv bov
Hose Techniques silicon hoses
Forge manual boost controller
boost gauge
K&N FIPK
ACT clutch kit HD-G6
Fidanza lightened flyweel
550cc RC Injectors
255lph Walbro Fuel Pump
LIPP Lexus AFM Replica
3" turbo back echaust with divorced
downpipe and no cats.
Aeromotive FPR
Aem Uego Wideband Gauge+O2 sensor
azerty is offline   Reply With Quote
Auto Tranny oil cooler mkiiisupra MKIII Supra 3 07-17-2008 11:50 PM
oil cooler supraman121 MKIII Supra 10 08-27-2007 09:23 PM
Cooler Throttlebody mrnickleye Non-Generation Specific Questions 1 05-03-2006 03:11 PM
cooler TRAFIK MKIV Supra 0 12-23-2005 04:41 AM
