Old 04-26-2008, 07:09 PM   #1
tak2099
tak2099's Avatar
tak2099 is on a distinguished road
Default check engine light trouble
i keep getting these codes:24-intake air temperature signal, 31-airflow meter signal, 51-air conditioner switch or neutral start switch signal, and 52-knock sensor signal. please give me as much info about all of these as possible.
I have an 89 supra turbo with 89,000 miles mostly stock. the only problem i know of is a hole in my turbo inlet hose, which i don't know if that would contribute to any of these codes.
tak2099 is offline   Reply With Quote
Old 04-26-2008, 08:21 PM   #2
Well, with the 24 and 31 it's either a bad KVAF or a short in the wiring harness.
The code 51, as stated in the TSRM, is often caused by someone hitting the throttle while the car is in the diagnostic mode or the A/C running at that time... less common is the possibility of a bad IDL switch in the TPS, bad switch in the A/C circuit or a fault in the wiring harness.
Knock codes come up for one of three reasons: knock, bad sensors or bad wiring...
No, the air leak shouldn't cause any of those codes.
Cygnus X1 Home Page
Note the links at the top right: TSRM (Toyota Service & Repair Manual), EPC (Electronic Parts Catalog), TEWD (Toyota Electronics & Wiring Diagrams)
Old 04-27-2008, 03:39 PM   #3
supramacist
supramacist's Avatar
See what I started with all of this 51 noise.
I should start a religion. Or a cult.
Where can we all get the exact same pair of nike's????
Old 04-28-2008, 08:18 PM   #4
tak2099
tak2099's Avatar
i very carefully cleaned the MAF, and the two intake codes haven't come back, but i still keep getting the knock and a/c switch one. how would i pinpoint which problem it is with the knock sensor?
Old 04-28-2008, 08:29 PM   #5
supramacist
You kind of just answered yourself mannnn.
Old 04-28-2008, 11:54 PM   #6
tak2099
tak2099's Avatar
i meant, how would i know if its the sensor itself, or the wiring?
Old 04-29-2008, 12:01 AM   #7
h8z2luze
h8z2luze's Avatar
Replace it...
EDIT: i just saw how much they are nevermind lol.
Old 04-29-2008, 01:48 AM   #8
^^^Yup, pricey...
Start with the rewire... search around there are a number of write ups about doing it on our cars on the net. It's not the worst job and 95% of the time the wiring is the problem.
Old 05-01-2008, 11:41 AM   #9
tak2099
tak2099's Avatar
k thanks, i hope its the wiring, because i don't have very much cash.
Old 05-01-2008, 12:16 PM   #10
mkiiisupra
Just do a rewire job cost like 50 bucks max for everything and thats if you have to buy a soldering gun, ill look up the write up on it for you
1990 Toyota Supra Turbo A/T
Check Engine Light & Warning light on Chomper MKIV FAQ 19 02-11-2011 12:51 PM
Check Engine Light joebuffalo MKIII Supra 4 05-08-2007 03:01 PM
Check Engine Light Johnny boy 82 MKIII Supra 2 06-09-2006 09:41 PM
check engine light ironcobra2002 MKIII Supra 4 11-05-2005 04:07 AM
