Old 04-25-2008, 08:17 AM   #1
sd88supra
Question advanced timing?
A couple months ago when I failed emissions I looked at the report and noticed the timing was off... too advanced. Well, it was set at 15? so I put it back to 10? and fixed the EGR (which was a pain in the ass) and passed emissions.
These were the effects: loss of power and crappier gas mileage. So it put the timing back to 15?. Got power back, only I've driven about 40 miles since I filled 'er up so I can't say anything about gas mileage improvement yet. My question is, is this ok? There's no knocking or pinging, and from what I've seen a lot of guys advanced their timing a little. I haven't been able to drive somewhere free enough to hit 80+ mph to see if my high end torque was reduced (which I suppose it was).
If I got lower mpg at 10? it seems like there was too much drag on the car from the lack of low end torque.
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
Old 04-25-2008, 02:27 PM   #2
I ran mine at 15* for years, with no problems. I run regular gas, and have never had a pinging problem. The knock sensor will back off timing if predetonation happens.
Best mileage was 25mpg, at 60mph for 120 miles.
Usually I get 22mpg, and of course I go 70-90mph on these open desert roads.
Old 04-25-2008, 04:07 PM   #3
supramacist
supramacist's Avatar
I need 20 miles to the gallon at like 85 mph. JOKE.
Doesn't running at 15* cause you to idle too high?
I assume you guys would adjust that out.
What kind of power are you picking up from advancing the timing by a few more degrees?
Aren't you losing low end by doing this?
How does it screw with your power band?
Old 04-25-2008, 09:00 PM   #4
sd88supra
Default a considerable amount
Yes, it does screw with the idle, but I also run 30 amp electric fans which when I turn on gets the idle back to ~700 rpm. Also, it does settle down by itself anyway. As far as power, I was surprised by how much of a difference it made. I wasn't expecting it to be as much. Then again, our cars are N/A. As far as losing high end torque, I would presume so, but I think MrNickleye can do a better job of answering. I'm not able to hit 90+mph often on these crowded city roads.
Old 04-26-2008, 08:36 PM   #5
Quit poking at the dizzy and just drop in a MAFT Pro or a MSD6 and play with the timing map across the board... no compromising for more low end + top end loss and so on.
5? of advance across the board doesn't make that much difference in my car at 30MPH or at 100MPH. It's an RPM specific thing, not related to speed at all. Keep that in mind when you're trying to figure out what works best for you.
Old 04-27-2008, 12:51 AM   #6
3.0trd
3.0trd is on a distinguished road
Default high idle
89 na manual. my problem is high idle. I jumped te1, and e1, timed it(set just above 10bdc) and it idles at 1000-1100 rpm. Not a huge deal, but I know if its idling high the timing won't be right, is there a way to manually turn down the idle?
3.0trd is offline   Reply With Quote
Old 04-27-2008, 02:49 AM   #7
I've never noticed a change in my idle with the base set at 10?, 15? or 20?.
If your idle if off then FIX IT. There's something wrong, the ECU thinks for one reason or another that the idle needs to be bumped and even if you get the timing right something else is bound to be off. There, I'm done... no more help regarding idle and timing issues from me. PERIOD.
Old 04-27-2008, 03:44 PM   #8
supramacist
Hey 3.0 TPS.
Check out the thread I pointed you too you'll get all of these answers.
I'm telling you dude I have asked these cats all of these questions and have a monster thread on the subject.
I can understand why cre is being short. My thick skulled arse put him and a few other through the exact same paces.
1991 n/a timing problems jerrods91supra Non-Generation Specific Questions 0 07-06-2008 09:44 PM
Timing question. supramacist MKIII Supra 53 04-26-2008 11:41 AM
Can't adjust timing... Lunch2000 MKIII Supra 7 11-26-2006 04:09 AM
timing issues stuck1 MKIII Supra 0 03-27-2006 02:16 PM
setting timing on a GTE djalkyd MKIII Supra 0 03-19-2006 04:39 AM
