Old 04-19-2008, 12:47 AM   #1
3.0trd
3.0trd is on a distinguished road
Default changing fuel filter
I have an 89 manual. How in gods name do you change the fuel filter? I can barely see it much less reach it. What is the best way to go about changing it?
3.0trd is offline   Reply With Quote
Old 04-19-2008, 12:51 AM   #2
supramacist
supramacist's Avatar
Which one?
Tank or inline???
Old 04-19-2008, 12:53 AM   #3
3.0trd
I thought there was only one, but I mean the one that sits on top of the differential bolted to the chassis
Old 04-21-2008, 03:53 PM   #4
j3pz
lol ya its a pain in the ass. i crawled under there to change mine and gave up. just reach up there and hope to god this time when you try to turn the wrench that you dont twist the lines. try doucing it in pb blaster/wd40 for like a week lol. thanks for reminding me i still need to wrestle mine
Old 04-21-2008, 09:21 PM   #5
3.0trd
I just can't believe they would do that, I hear the mk2's have them right by the steering column by the firewall, wonder why they would move it to a place like that...
Old 04-21-2008, 10:42 PM   #6
supramacist
If you want easier access you will have to drop the tank which isn't a big deal after you get the system down that works for you.
Old 04-22-2008, 11:26 AM   #7
IHateHacks
IHateHacks's Avatar
Get yourself a 14mm Flare Nut wrench.
It can be done without dropping the tank.
Old 04-22-2008, 01:53 PM   #8
supramacist
He's got a fuel filter in the tank. If he's got fuel filter problems he should change them both because the chances are the one causing him problems is inside the tank.
Just an opinion though. Those lines twist easy and they aren't cheap to replace. If you kink them you may as well replace them.
Old 04-22-2008, 08:30 PM   #9
IHateHacks
IHateHacks's Avatar
Yes, that's correct.
But out of all the tanks I've dropped, I have yet to see the in tank "filter" be clogged at all. It is more of a screen than a filter. It "screens" the big stuff out before it has a chance to clog the in line filter.
Work on this car enough and you'll be wondering why they did ALOT of things. For example, the seven 14mm allen head plugs in the center of the cylinder head. Or how about this gem: the 17mm allen head plug UNDERNEATH the EGR cooler. That's the winner. I can go on all day..... Why did they use such soft aluminum alloy for casting the cylinder head? Why did they put the CPS on the hot side of the cylinder head? Why is the factory head bolt torque value 58ft/lbs?
Old 04-22-2008, 10:47 PM   #10
supramacist
Alright..., I get your point on the in tank screen/ filter whatever it needs to be called.
I have seen them mucked up and cleaned easily with gas and an old toothbrush so long as the attachment is in tact.
Fuel Filter scruffboy Non-Generation Specific Questions 6 08-16-2007 03:20 PM
Fuel filter location? supraman121 MKIII Supra 1 05-26-2007 08:23 PM
Fuel filter mr.w MKIII Supra 3 01-24-2007 09:47 PM
where is the fuel filter located??? redmaro MKIII Supra 3 08-23-2006 04:31 PM
Fuel Filter 559turbo MKIII Supra 5 11-23-2005 12:22 PM
