Old 04-27-2008, 12:39 PM   #61
Bill UK
AEM EMS
Bill UK's Avatar
There you go !, Price in 2006 was ?77.00
Contact Del Johnson,
Kent Performance Camshafts Ltd.
Units 1-4 Military Rd,
Shorncliffe Ind Est.
Folkestone.
Kent.
England.
CT20 3SP.
Tel: 00 44 (0)1303 248666.
Fax: 00 44 (0)1303 252508.
WWW.KENTCAMS.COM
Old 04-27-2008, 03:14 PM   #62
Bill UK
AEM EMS
Bill UK's Avatar
Andy, I marked up some hoses in red and blue in the pic`s in my earlier post. The blue hose which supramacist was referring to (“Lower block hose back behind those pesky starter bolts”) on early Supras was capped off with a rubber end cap, on later Supras this was redesigned so the pipe terminated with a metal end cap. The hoses marked in red are the 90? elbow hoses I was referred to in my earlier post.
Old 04-27-2008, 03:42 PM   #63
supramacist
supramacist's Avatar
Does he have the metal coolant lines that run the length of the block?
Old 04-27-2008, 04:51 PM   #64
Andy C
Andy C's Avatar
thanks bill emailed them today,
supramacist i think i do have the metal ones that run the length of the block cheers all. you all being a great help just waiting for the cam seals to be replaced and the o ring fitted in the cps then i should be able to start rebuilding her.
Old 04-27-2008, 06:07 PM   #65
supramacist
Ya...., I just blew the coolant line coming from the water pump to the t-stat housing. Yeeehaw.
Luckily I have just replaced a different coolant line and I may be able to scavange a bit here without ordering a new line.
None the less I'll call monday and get a price and an eta if I order it.
Old 04-28-2008, 10:51 AM   #66
Cool
i'm starting to hear that ozzy song
Old 04-28-2008, 05:23 PM   #67
Andy C
Andy C's Avatar
Unhappy
phoned kentcams today they wanted 170 quid forthe head studs!
think ill check ebay instead hopefully itll be cheaper getting them from america.
eBay Motors: ARP 203-4202 TOYOTA 7MGTE:SUPRA HEAD STUD KIT (item 360045965042 end time Apr-30-08 12:00:26 PDT)
are these the ones i need??
Old 04-28-2008, 07:26 PM   #68
supramacist
Whats 170 quid American???
Old 04-28-2008, 09:29 PM   #69
Bill UK
AEM EMS
Bill UK's Avatar
A quid is slang for one ?1 GBP
?170 GBP (Great Britain Pounds) = $338.56 at today’s exchange rate. Yes you need to be a really dedicated owner of a Supra in the UK. Andy check any import duty, they may even send them as a present,which will be exempt from duty. Either way I would go to the US for them. While your at it, get me some ADR alloy wheels, ADR `s are not obtainable in the UK.
Old 04-28-2008, 09:32 PM   #70
supramacist
Yes. He should be able to buy them around 225$ and have them shipped for alot less than 100 bucks.
I'd order outside my country. Can't be any worse than dealing with canadians.
