Old 04-28-2008, 12:28 AM   #31
I posted in a thread about the Lex AFM. It apparently does use the same electronics as the 7M-GTE... I have no idea why everyone insists it doesn't....
Seriously, I don't know who's right now and as such I'm just going to stay away from that topic hence forth.
Old 05-01-2008, 06:08 AM   #32
sold my malibu
sold my malibu is on a distinguished road
Default probably safest
On another note.
heres one:when I start my car often it feels like it is starting rich.It stumbles and sounds shitty for maybe a minute.I am checking the timing tomoorow. (I was too busy today replacing the deck some idiot tried stealing and only succeeded in completely bastardizing it).But when I was going through the trouble with the afm I got a code about the starter.code 43.Or could this also be the TPS requirering adjustment.It runs fine after it catches itself though.
Feel free to chime in supramacist apart from the past You may have some benificial ,contribital knowledge.
blittz boost controller
3 inch with divorced downpipe
HKS BOV
2 inch drop (front)
shaved rear wiper and entenna
sold my malibu is offline   Reply With Quote
Old 05-01-2008, 06:15 AM   #33
supramacist
supramacist's Avatar
Don't start adjusting that tps unless you have a 51...., or you'll throw a 51 as well. I just went through all of that. I mean the idle screw and the dashpot to be more specific.
Old 05-01-2008, 06:20 AM   #34
supramacist
This may help you. maybe. maybe not.
http://www.toyota-supra.info/forums/...-question.html
Old 05-02-2008, 04:00 AM   #35
sold my malibu
Ah, gotcha. Sorry, I didn't see that mentioned previously.
I know how boost controllers work and can usually set them up pretty quick, but that model's unknown to me.
What's the present setting on the controller? The BOV isn't venting at all or you just don't hear it? Is the BOV routed to the intake or open to atmosphere?
EDIT: Well, if you're looking to learn here's a guide from our distant cousins the 3000GT crowd (*me* ducks the heavy objects now poised to be thrown in my direction). This looks like it covers things fairly in depth, although cut back on the boost settings until you have a feel for what the turbo has to offer before it chokes.
SwissCars / Blitz DSBC Installation
EDIT 2: Forgot to mention that you should also check that the SBC's vacuum line is connected and that there are no leaks.
here's the manual:
http://www.blitz-performance.com/inc...Spec%20S&R.pdf
I downloaded the manual and keep it in the glovebox.I have it set at 5 gain and # 1 at 20% it runs nice man.I am interested in shimming the waste gate is this a simple job?or in hours with corect tools
HKS BOV
2 inch drop (front)
Old 05-02-2008, 04:16 AM   #36
Shimming only takes a few minutes... getting it just where you want it is another thing. Although with the Blitz you shouldn't have any need to shim the wastegate... so, what's up?
Old 05-02-2008, 05:43 AM   #37
sold my malibu
Default your right
after posting I did wonder about that.I need to understand a little more about this area
I have a spare ct26 on the kitchen table right now and had to laugh because the owner of it had the washers on the nut side.I couldn't see how this gained anything.But I had the chance to learn alittle more.
I may switch actuators tomorrow as i have what seems like some exhaust coming out of my divorced pipe at idle.I don't know if they are prone to failure or not.I suppose the spring mechanism could tire.
It should be closed at idle correct.
HKS BOV
2 inch drop (front)
Mechanic says it’s not the head gasket. 87 Supra MKIII Supra 23 03-29-2008 03:01 AM
talking with mechanic? scruffboy Non-Generation Specific Questions 4 04-18-2007 03:03 AM
need mechanic or any sort of help! xs87supra MKIII Supra 10 12-30-2006 04:11 PM
my friend 90mkiii turbo has no spark supradefiant MKIII Supra 2 09-01-2006 06:27 PM
friend needs help disturbednitehawk Off Topic Forum 8 11-24-2004 11:21 AM
