Old 03-25-2008, 06:13 AM   #1
neverbeencaught
neverbeencaught's Avatar
neverbeencaught is on a distinguished road
Default replace engine
hey I really badly need a write up on how to replace the stock 7mgte engine. I've got it set in and bolted down but I don't know the wirring, pipping, and that. PLEASE HELP!!!
neverbeencaught is offline   Reply With Quote
Old 03-25-2008, 01:04 PM   #2
Chambers
Chambers's Avatar
This is in the stickys, good luck.
MK3 TSRM On-Line
"Stuck in the 80's"
Old 03-25-2008, 01:50 PM   #3
mkiiisupra
Head Gasket Dismantling 5-14-05
Alot of pictures here of the dissasembly of the head and such maybe will help u identify waht to hook up where
1990 Toyota Supra Turbo A/T
Old 03-27-2008, 05:16 AM   #4
neverbeencaught
thanks guys, that's really helpfull. I'm also wanting to build the engine while it's apart. what would you suggest to do if I want to jack the boost up to about 25 with a new turbo. I'm wanting to put atleast 450 whp. so give me some advise.
Old 03-28-2008, 06:26 AM   #5
neverbeencaught
bump for good faith,lol.
Old 03-28-2008, 07:57 AM   #6
SideWinderGX
if your getting a new turbo, 25 psi is WAY overkill. mid teens is whatll get you 450 whp, give or take some. look into the rebuilt ct26-57 trim turbos.
assuming its a manual...make sure the headgasket is replaced with a MHG and arp studs, torqued to about 75/80 ftlbs, make sure the engine has no problems whatsoever, 3" exhaust from the turbo back, intake, boost controller. personally id put in a new intercooler and pipes just to ease up the work the turbo has to do, but its not exactly necessary. drop in the 57 trim, tune with your tuning equipment of choice, and there you go. and a new clutch, youll probably need it.
my car:
Bottom end rebuild or replace engine ? lensosupra MKIII Supra 3 05-06-2008 12:19 AM
Parts to Replace When Replacing Engine born2drv MKIII Supra 6 10-23-2005 09:41 AM
