Old 05-31-2008, 01:19 PM   #31
supramacist
supramacist's Avatar
I have heard alot more about nippon than beck and arnley or whatever that stuff is.
Check out: Performance Parts Aftermarket and Racing
See what these guys carry. Call them and dial ext 103.
Speak to Dave. If he can't find you some quality rings at a fair price.
He can point you to them.
O'rielly's is the lowest grade parts distributor I will use on the supra and I am so utterly choosey about not having to keep working on this tramp that I refuse to stoop to lower quallity parts..
Not that this has aided my car in running or anything but it should when I get it sorted out somewhere around 2010.
Old 06-07-2008, 04:13 AM   #32
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
As far as lifting the engine a few inches, is there anything else that needs to be unbolted besides the engine mounts? is there anything holding the transmission down? thanks in advance
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
Greddy e-01 boost controller
245's all around
Slotted + drilled all around
3" straight piping turbo-back, 4" tip
Lowering springs
HKS mushroom air filter
paulmicin is offline   Reply With Quote
Old 06-07-2008, 06:47 AM   #33
CyFi6
Please read the tsrm! There are other things, yes.
edit: thought you were removing the engine
Old 06-09-2008, 07:06 AM   #34
paulmicin
paulmicin's Avatar
So it turns out you cant lift the engine just enough to remove the oil pan, it needs more clearance than that. The tsrm states that you can just lower the crossmember with a jack and put it on 2 jack stands. what i want to know is, is the crossmember balanced from the center? or is it going to lean towards the back of the car when i try to lower it with a jack?
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
245's all around
Lowering springs
Old 06-09-2008, 11:18 PM   #35
paulmicin
paulmicin's Avatar
Hey look what i found!!!
That aint no piston ring. damn crappy stock pistons. guess its time to get some nippon pistons.$100 for a set with new rings. not bad i think.sorry its not eagle, im not rich.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
245's all around
Lowering springs
Old 06-13-2008, 06:00 AM   #36
burton51m
burton51m's Avatar
Nice find! lol. What does the block look like?
Old 06-13-2008, 12:47 PM   #37
paulmicin
paulmicin's Avatar
the cylinder walls are mirror smooth. lucky me i guess. There was much antifreeze in the oil pan and under all the rod bearings, but i am changing them out. I only drove it like 5 miles since i got it so there shouldnt be any damage to any major parts.
1989 5 speed turbo
Koyo radiator
Spearco intercooler
HKS bov
245's all around
Lowering springs
Old 06-13-2008, 03:23 PM   #38
CyFi6
You should get someone to check out the block, might look okay on first glance but it could be scored and or be out of round/tapered.
Old 06-16-2008, 01:26 AM   #39
burton51m
burton51m's Avatar
True, that piston had to be rubbing on something....
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
