Old 04-01-2008, 12:25 AM   #11
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Bolts have heads on them, while studs do not. You use nuts on the top of studs.
I could have made clearance for the ARP bolts, but I didn't want to do any grinding while the head was on, and I sure wasn't going to pull it back off. So I just reused the stock head bolts.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 04-01-2008, 12:48 AM   #12
Originally Posted by paulmicin View Post
I was also wondering if this is the stock fuel rail.
I believe so... The rail on my N/A looks nearly identical
Old 04-04-2008, 02:15 AM   #13
paulmicin
paulmicin's Avatar
paulmicin is on a distinguished road
Well its off now. Do you guys think these scratches will be a problem with the new hg.
paulmicin is offline   Reply With Quote
Old 04-04-2008, 04:19 PM   #14
Benesesso
Benesesso's Avatar
That should be resurfaced! Those "minor erosion cuts" are in the worst possible direction--a sure future leak path.
Old 04-05-2008, 02:04 AM   #15
paulmicin
paulmicin's Avatar
Damn, i was hoping it wouldnt be that bad. Whats a good place to get it resurfaced for cheap?
Old 04-30-2008, 02:19 PM   #16
paulmicin
paulmicin's Avatar
Finally put it back together. put a new head gasket and water pump just because. but its putting out even more smoke than before. when i got the head back from the machinist it had ridges the whole way across the surface. was it supposed to be like that? also its shooting out smoke from the pcv and theres a lot of pressure in the valve covers.am i going to have to take it apart again and have the head reresurfaced? did i not torque it right, i put it to 75 ft/lbs.
this sucks ass
Old 04-30-2008, 03:24 PM   #17
supramacist
supramacist's Avatar
The head will not slide down to the head with the studs inserted.
You have to drop it onto the guidpins and then install the washers and then the studs or you'll be pulling the head off and on till you do it the right way.
Old 04-30-2008, 06:12 PM   #18
Whoa, 50psi on #1 and only 70 wet? So have you replaced the rings or not? Is your dipstick getting blown out yet?
Old 04-30-2008, 08:00 PM   #19
supramacist
Pardon the pun.
I'd lap that block at home. If that's the worst damage you have.
Mine was much much worse.
Old 04-30-2008, 11:09 PM   #20
paulmicin
paulmicin's Avatar
I didn't have a problem lining up the head i just put it on and dropped the bolts in the holes.
the block is smooth i dont think thats the problem. i havent changed the rings. the seller told me it was a low mileage engine that he swapped in so i doubt its the rings.i also noticed white stuff on the oil cap but that could just be this grease that the machinist put on the lobes and lifters when i got the head back. i have the pcv rerouted to a catch can and then to the atmosphere and theres white smoke coming out of the pcv lines.how can there be smoke. there wasnt any before. can all this be explained by a badly resurfaced head?
Compression check when cold gottadiesel MKIII Supra 3 02-26-2009 07:24 AM
Compression and Block Tests mrnickleye Supra FAQ 0 01-29-2007 03:49 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
looking at a 90 turbo with compression problems jtitzer56 MKIII Supra 1 09-23-2006 05:27 PM
Compression Question Intenseneal MKIII Supra 5 08-15-2005 10:27 AM
