Old 03-21-2008, 06:10 AM   #1
FunWheelDrive
FunWheelDrive is on a distinguished road
Default Take out Release Fork?
I'm in the process of taking out my transmission and it looks like all i need to do to make the tranny come out is take out the clutch release fork. How the hell go you get that thing out of there? The TSRM manual says, "remove fork" but it doesn't tell you how to release the fork. I see two fourteen mil bolts but there isn't enough room between the fork and the bolts to get a wrench or a socket in there. Any help would be great.
FunWheelDrive is offline   Reply With Quote
Old 03-22-2008, 05:28 AM   #2
jfunez
jfunez's Avatar
you can also go by removing the E-clip that holds the pin through the fork. a bit hard and easy to loose but is quicker...good luck
Old 03-24-2008, 05:33 AM   #3
FunWheelDrive
I have the r154 transmission, there are no clips on it. I have no idea what you guys are talking about when you say take off the clips. There are no clips! There are 2 12ml bolts. I got one loose the other is impossible to get off, there is 2mm's from where the bolt is to where the fork stand is. On the pivot point i see no clips nothing, just one end that has a weird shape, the other end is a round tube, i tried hammering on the tube lightly and again it didn't budge. How the hell do i get the fork off.
trunk release cable? dannydavi MKIII Supra 10 02-13-2008 09:38 AM
87 supra hood release problem EvilDragun Non-Generation Specific Questions 6 01-11-2008 01:38 AM
Hood release cable catawalks Non-Generation Specific Questions 11 04-24-2007 03:04 AM
No release west_side_supra MKIII Supra 16 11-20-2006 05:43 PM
Quick release hub adapter!? 88Supraboy MKIII Supra 4 03-04-2006 04:10 PM
