Old 03-08-2008, 12:56 AM   #1
supramacist
supramacist's Avatar
Default power steering air control valve.
Does anyone have one of these things for the power steering pump that they wish to part with???
Toyota is crazy insane on how much they want.
They want over 200$
Old 03-08-2008, 05:32 AM   #2
mkiiisupra
mines busted. i just caped off the lines running to it.
It only increases ur idle while turning in parking lots. not a necessary part
1990 Toyota Supra Turbo A/T
Old 03-08-2008, 06:08 PM   #3
supramacist
How much pressure does that push through there?
What did you cap it with? I automatically started thinking a screw right into where it broke with some rtv on it would probably do the job.
Old 03-09-2008, 11:30 PM   #4
mkiiisupra
See the two black circles? that is where i capped it off at. just bought some rubber caps from autozone attached one to that metal line, and the other to the bottom of the accordian hose, which is where the other end of that line runs.
Old 03-09-2008, 11:33 PM   #5
mkiiisupra
http://www.toyota-supra.info/forums/...oken-help.html
That was the post from awhile back where i was helped through the process if u have any more questions
Old 03-09-2008, 11:55 PM   #6
supramacist
Ya I was thinking backwards a bit.
I'm solid. That pic of yours was the shizzle.
Highly appreciative.
power steering wont bleed please help. carnahkt MKIII Supra 5 01-24-2009 09:20 PM
power steering pump daluxsrt4 MKIII Supra 1 08-29-2008 02:17 PM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering fault david small Non-Generation Specific Questions 1 09-20-2006 12:41 AM
Air Control Valve nickvash0104 MKIII Supra 0 03-07-2006 06:26 PM
