Old 02-20-2008, 07:42 PM   #1
mkiiisupra
Default Compression Test
Finally got around to doing one of these, was scared to becuase couldnt really be sure of the quality of job the shop did on my engine. I got 160 across the board.
Are those normal values? Seems like my engine is in good shape
1990 Toyota Supra Turbo A/T
Old 02-20-2008, 08:14 PM   #2
mkiiisupra
Perhaps i did the test wrong? idk tsrm says 142? heh. i cranked the engine about 7 times on each cylinder, all hit 160 at 6th crank if i remember right and 7th was to make sure didnt rise ne more.
Forgot to check 1st jump of needle, pretty sure it was 90 on each one. would have to do again to be sure
Should probably get one of those kits that lets u start the car while looking at engine bay would of made life easier
Also was done on a cold engine, dont know if this makes a diff but didnt notice it was supposed to be at operating temp untill i had it apart lol
Old 02-20-2008, 10:58 PM   #3
supramacist
supramacist's Avatar
Do you hot rod it cold or at operating temp???
I would do it cold and warm.
Old 02-20-2008, 11:35 PM   #4
mkiiisupra
not sure what u mean... But i did the test cold ill prolly do again later at op temp and be sure to check first surge of hte needle. how long do you crank it just for like a sec then let off and do again right?
Ohhh, i make sure she is fully warmed up before i let her boost at all.
Old 02-20-2008, 11:51 PM   #5
supramacist
You only let the engine crank 1 rotation.
If it were me I would do it at operating temp which the tsrm states...,
takes 20 minutes at idle is required for optimum operating temperature.
Old 02-21-2008, 12:05 AM   #6
mkiiisupra
ya i just noticed it after i took off the intake and spark and thorttle body lol
Old 02-24-2008, 03:36 PM   #7
mkiiisupra
Redid the compression test these are the numbers i go
Cylinder #| First needle movement | Max Compression |
1 | 80 | 171
2 | 90 | 170
3 | 80 | 173
4 | 80 | 171
5 | 80 | 176
6 |80 | 171
Old 02-24-2008, 08:12 PM   #8
CyFi6
Make sure you disable fuel and hold throttle at wot (unless you had to remoce the throttle body to get to theplugs anyways. Excessive compression can be cause by many things such as carbon buildup in the cylinders or just have the head shaven down enough
Old 02-24-2008, 08:39 PM   #9
mkiiisupra
bah. looks like i will be doing another test lol
Cant seem to do it right, forgot to open throttle up >.<
How do you disable the fuel?
Old 02-26-2008, 11:27 PM   #10
mkiiisupra
bump. do i just pull the EFI fuse to disable the fuel system?
compression test question mastergrader007 MKIII Supra 2 08-09-2008 12:05 AM
WOW did a compression test now i got code 12 n 14 help 88Tsupra MKIII Supra 9 06-30-2007 08:19 AM
Just did compression test...Help with oil pressure! 2JZEFINI-17 MKIII Supra 1 11-06-2006 12:06 AM
what are factory compression test numbers? 2JZEFINI-17 MKIII Supra 1 11-05-2006 11:58 PM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
