Old 02-05-2008, 05:45 AM   #1
88suprana/t
88suprana/t is on a distinguished road
Default NA to JDM turbo
Hello all I am a total noob to supras. I just purchased an NA with a blown engine for $300. I'm playing on doing the typical NA to T swap and am planning on buying a JDM motor. 86-92 JDM 7MGTE 3.0L TURBO SUPRA COMPLETE ENGINE LONGBLOCK JDM TOYOTA SUPRA 3.0L ENGINE 7MGTE TURBO SUPRA [7MGTE] - $1,050.00 : got-jdm.com, JDM Imported Engines, Performance Auto Parts at Wholesale Prices
I was wondering what EXACTLY would I need OTHER then what comes with the longblock shown here? Any links would be helpful. I also read someone on here bought a JDM block and had to purchase the wiring harness for a US model from toyota.... How much is that?
88suprana/t is offline   Reply With Quote
Old 02-05-2008, 01:56 PM   #2
linuxgurupodboy
linuxgurupodboy's Avatar
linuxgurupodboy is on a distinguished road
Buried in this forum is all the answers, dig deeper, also look at the trsm. If you gonna drive it like my grandma, you can probably get away without changing the gearbox and diff.
1990 3.0Ltr GT Turbo @8psi Manual (Converted)
linuxgurupodboy is offline   Reply With Quote
Old 02-05-2008, 03:35 PM   #3
supramacist
supramacist's Avatar
The you may as well find the cheapest pos jdm engine you can because it has to be rebuilt before you can install it and begin trusting it.
To skip this is almost certain death and a deeper more vast money pit.
Old 02-05-2008, 05:19 PM   #4
88suprana/t
then what about this? eBay Motors: Rebuilt Toyota Turbo Supra Engine 7MGTE Cressida 7MGET (item 320213002477 end time Feb-07-08 18:46:11 PST)
Only problem with this is I'm doing an NA/T swap. How much extra money am I looking at for all the motor accessories, turbo, manifold, etc. etc.
Old 02-05-2008, 05:32 PM   #5
Chambers
Chambers's Avatar
Yea, supramacist is absolutely correct, if you don't rebuild it, it may work for a while, but the inevitable will happen.
"Stuck in the 80's"
Old 02-06-2008, 05:33 AM   #6
Pretaco
The pistons are different between the n/a and the turbo, don't think that you can just bolt a turbo on and it will be good.
Ray.
Currently Running Good
Old 02-09-2008, 04:52 AM   #7
supramacist
Maybe you can find a usdm dealer that remans jdm engines.
Good Luck with it whichever you decide.
