Old 01-25-2008, 04:25 AM   #1
SilenceboneSupra
SilenceboneSupra is on a distinguished road
Default Electric Fan Controller Temp. question
since the fan shroud of my '92 supra was broken and couldn find any replacement i decided to go get 2 Hayden 3690 electric fan for my car. i got a new radiator and the fans fitted nicely on it, afterwards i went and got a Hayden Thermostatic Electric Radiator Fan Controller for the fans.
The controller can be set between 160F - 230F.
My question is at what temp should i set it?
SilenceboneSupra is offline   Reply With Quote
Old 01-25-2008, 06:15 AM   #2
OfnaRcR
200? I'm not sure.
Old 01-25-2008, 04:09 PM   #3
Pretaco
I just set my electric fans up to the factory switch on the thermostat housing. If you want the temps that it uses to turn on and off, check the repair manual under the air conditioning section, under system operation it will give you the temps used to turn on and off the fans. I'm thinking of getting some pics and doing a writeup on how to use the factory switch and relays to control aftermarket fans.
Currently Running Good
Old 01-25-2008, 04:15 PM   #4
Pretaco
Actually its kinda hard to find if youre not familiar with the factory repair manual and the ewd. This is the page of the ewd that has the temps:
http://http://www.cygnusx1.net/Supra...x?S=Main&P=145
They turn on at 212°F, and off at 203°F.
The 212°C is a misprint.
Old 01-26-2008, 04:11 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
I don’t think that link is working Pretaco, try these.
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=CO&P=3
http://www.cygnusx1.net/supra/Library/TSRM/MK3/manual.aspx?S=AC&P=33
Old 01-26-2008, 08:17 PM   #6
And here's the original link... had an extra "http" in it:
MK3 TEWD On-Line
Electric Fan? mkiiisupra MKIII Supra 24 06-18-2010 08:26 PM
Pulling ICE and related parts and GOING ELECTRIC ddmcse MKIII Supra 6 12-11-2008 09:40 PM
Manual Boost Controller and Turbo timmer question ethan12510 MKIII Supra 5 02-20-2008 10:54 PM
How to install a oil temp controller ? Supra-Iceman Non-Generation Specific Questions 4 01-30-2007 11:18 PM
Temp. Sender-what does it do? Benesesso MKIII Supra 2 05-10-2006 03:06 AM
