Old 01-15-2008, 05:27 PM   #1
Sinistral
Sinistral is on a distinguished road
Default MK4 tranny swap
Is it possible to swap a MK4 transmission into a MK3? If so, has anyone actually attempted this?
Sinistral is offline   Reply With Quote
Old 01-15-2008, 11:41 PM   #2
Pretaco
Pretaco is on a distinguished road
Everything is possible.
Are you trying to use the getrag 6 speed with your current 7m engine?
As far as I know that is not possible, I was told by a mechanic familiar with these cars, that to swap in a 2jz, you have to have the getrag 6 speed, so I would assume the opposite is also true.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
Old 01-16-2008, 04:14 AM   #3
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
anything can be done woth money but people mainly just go with r154.
pretaco that is false, a lot here in socal have 2jz mk3's what you do is you get r154 with a 1jz bellhousing since 1jz's came with r154's and all jz engines have the same bolt pattern. you can put a getrag v160 in a mk3 but its just too much work for an overpriced transmission
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 01-16-2008, 04:35 AM   #4
Pretaco
Cool, so maybe my 2jz swap is feasible.
Thanks for the info.
Old 01-16-2008, 11:36 AM   #5
Supra2NR
Supra2NR's Avatar
i recently swpped a 2jz into a nissan s14
due to tranny tunnel clearance issues we used
a r154 transmission
all we needed was use a 1jz bellhousing
so reverse the process
put a r154 bellhousing on a getrag trans
and it can be used to mate to a 7m motor
thats what im planning soon, if i can come up with 3000 dollars
Old 01-16-2008, 02:10 PM   #6
Chambers
Chambers's Avatar
I don't think the Getrag has a removable bell housing. Does it?
"Stuck in the 80's"
Old 01-17-2008, 12:42 AM   #7
oowee623
oowee623's Avatar
i doubt that r series and v series trannies have the same bolt pattern
Old 01-18-2008, 01:07 PM   #8
Supra2NR
Supra2NR's Avatar
can it? does anyone know if the getrag has a removable, belhousing?
cuz if the 1jz bellhousing that can be used with the 2jz, and can also be mated with the r154,
and adapter plate is feasible,
if they can put a chevy trans into a toyota
why not another toyota trans into another toyota?
Old 01-18-2008, 03:27 PM   #9
Pretaco
I took the liberty of googling pics of getrag transmissions......
and....
and...
did not find any with removable bellhousings.
So, the 1jz/2jz swap works with the 1jz bellhousing and r154, but the getrag 6 speed swap doesn't work without a 1jz or 2jz.
For those of you that don't like to read:
r154 + 1jz bellhousing + 1jz/2jz =
getrag 6speed + 7mgte =
Ray.
tranny swap speedyfran MKIII Supra 1 08-01-2007 02:51 AM
Tranny Swap RedMan Non-Generation Specific Questions 0 05-24-2006 09:42 AM
tranny swap question flight doc89 MKIII Supra 0 05-05-2006 03:15 AM
