Old 01-13-2008, 12:32 AM   #1
Aurake
Aurake is on a distinguished road
Default What is the stock car's recommended fuel?
I just picked up a 1990 n/a automatic, but it has no information with it. Does it have enough compression to make use of premium gas? Or should I just stick with regular?
Aurake is offline   Reply With Quote
Old 01-13-2008, 02:16 AM   #2
Supra2NR
Supra2NR's Avatar
premium should be better, burns off cleaner
Old 01-13-2008, 03:13 AM   #3
Aurake
Yeah but what I want to know is what the recommended fuel is for the n/a. It's not accelerating as well as I think it should (I have a prelude that's 200hp and a bit lighter, so I'd think it'd be similar). The car's body is in great shape, the engine seems pretty good except that some coolant had leaked. I talked to the guys who worked on it, they said they'd filled it up with regular.
I want to know if the engine is retarding the timing and that's why there's so little power, or if this is indictive of something else?
Old 01-13-2008, 04:01 AM   #4
mkiiisupra
dont think your fuel is causing the computer to retard the time, check for codes...
Knock sensor will do it, or if ur TPS is not calibrated....
Or air leaks, vacuum leaks... check it all lol
1990 Toyota Supra Turbo A/T
Old 01-13-2008, 04:26 AM   #5
Supra2NR
Supra2NR's Avatar
even when i had my NA
i always used premium gas
and regular, only when i dont have money
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
Stock Fuel Pump..how many LPH?? recomendations christutecky MKIII Supra 2 06-19-2006 03:42 PM
1JZ-GTE Engine with 7mge Stock Fuel Pump joolhamdi MKIII Supra 1 06-10-2006 10:29 AM
stock fuel pump replacement unclebenny MKIV Supra 7 10-26-2005 12:34 PM
