Old 01-10-2008, 09:08 PM   #1
Irish_Mechanic
Irish_Mechanic is on a distinguished road
Question Auto Trans Issue
My auto trans gives me intermittent trouble. Occasionally, when i put the shifter to 'low gear' to come off the line, it lags like its in second, then drops itself into neutral and revs. Anyone else experience this?
I'm not a trans guy, so i'm sorta outside my experience...
Irish_Mechanic is offline   Reply With Quote
Old 01-02-2010, 10:44 AM   #2
chino1123
chino1123 is on a distinguished road
is the neautral switch sensor is locate in the passenger side nest to the trasmission stick
chino1123 is offline   Reply With Quote
Old 01-04-2010, 03:25 AM   #3
Green7mgte
Supra Forum Moderator
is that a question or an answer. just a bump into the thread, what is my shift lock overide button for? sorta along the lines of the thread
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 01-04-2010, 04:06 AM   #4
chino1123
that is and answer your car problem is that neutral swich sensorh control the shift in your car i have the same problem in my and that i was the problem
Old 01-04-2010, 04:16 AM   #5
Green7mgte
what does the neutral switch sensor do?
Supra FAQ
Supra MKIII FAQ
Old 01-04-2010, 04:25 AM   #6
chino1123
go to the web this well help you http://www.cygnusx1.net/Supra/Library/TSRM/MK3/ that show you what to do
Old 01-05-2010, 02:53 AM   #7
Krem
I had an automatic 89 mercury topaz that I used to drive in similar manner... so it'd hold the lower gears longer rather than shifting when only at 2500-3000 rpm. Sadly... several months later, she would not shift past 2nd when I had her in drive... it started slow, slipping in the lower gear longer if I kept my foot on the peddle... if I let up and it did shift, as soon as I reapplied the gas, it'd downshift back to the lower gear..
I ended up ditching the PoS... the car cost me $1100 and at the time, I was young and dumb, figured the tranny was fuxed (which could be for all I know) and there was no way I was going to pay even a grand to have it repaired... not like it's a mk3 supra or something worth keeping... either way, since then, I've tried to avoid driving my automatic manually like that.. even tho the supra could really benefit in acceleration for me that way (mine is NA auto, not turbo manual, I could use any help I can get in acceleration.)
Old 01-05-2010, 03:47 AM   #8
Is the overdrive engaged? heh.
Neutral start switch is a starter lockout, it ensures the transmission is in either Neutral or Park when starting the car. It is not wired in to the ECT as far as I can tell: http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=107
Check for diagnostic codes: http://www.cygnusx1.net/Supra/Librar...aspx?S=AT&P=13
TPS Sensor and Auto Trans btwilson86 MKIII Supra 5 02-12-2008 07:31 PM
88 Turbo, issues with Auto Trans Staceman MKIII Supra 5 08-13-2007 09:51 PM
Auto vs. manual trans. rnoswal MKIII Supra 9 12-14-2005 01:54 PM
