Old 01-07-2008, 08:14 PM   #1
WhiteTurboZ89
WhiteTurboZ89 is on a distinguished road
Default 7mgteu 267 hp engine
i heard that in 1988 japan came out wit 500, toyota supras wit 7mgteu engines that produce aruond 267 hp stock. i was wonder if the 7mgteu fit into the reg supras. If it does any1 know how much it cost?
WhiteTurboZ89 is offline   Reply With Quote
Old 01-07-2008, 08:29 PM   #2
OfnaRcR
Where did you hear this? I'm not familiar with this? Is it the A?
Old 01-07-2008, 08:45 PM   #3
WhiteTurboZ89
Default here is the website
Turbo-A.net :: Toyota Supra Turbo-A - Content
this is the website i found the 7mgteu engine. its from the 1988 turbo a model wit 267 hp.
can that engine be put into my 89 supra? 30 hp on stock is a big differences.
im new to cars in gerneral sry for newb questions.
Old 01-07-2008, 09:41 PM   #4
781supraturbo
781supraturbo's Avatar
781supraturbo is on a distinguished road
yes it can fit and it will be fine on stock
781supraturbo is offline   Reply With Quote
Old 01-08-2008, 04:20 PM   #5
86SupraMan
86SupraMan's Avatar
86SupraMan is on a distinguished road
good luck getting the engine though. limited production means limited engines =\
now u gotta find a decent condition working one.
86.5 Toyota Supra
((Current Mods)) :
-Slotted/Crossdrilled Rotors
-K&N Filtercharger
-H4 Projection light Conversion
-Magnaflow Catback Exhaust
-=Mods to do=- :
-Rust Repair
-Bodykit
-Paintjob
-Engine work
-Suspension
-Wheels
-Intake (Semi-Done)
-Exhaust
86SupraMan is offline   Reply With Quote
Old 01-10-2008, 12:49 AM   #6
Supra2NR
Supra2NR's Avatar
its says it can accelerate from 0-60 in 3.0?
3600lbs+267hp? 3.0 seconds?
Old 01-10-2008, 03:09 AM   #7
dcrusupra
dcrusupra's Avatar
KPH, which is about 37 mph.
New Rebuild
My CarDomain
Old 01-11-2008, 12:04 AM   #8
Supra2NR
Supra2NR's Avatar
oww, thats why,
Old 01-12-2008, 08:52 PM   #9
oowee623
oowee623's Avatar
called the turbo a supra with black exterior, black sawblades, and black interior with recaro seats and momo steering wheel, the engine difference it that the ct26 turbo in it is bigger and it uses maf instead if an afm. it also has a air duct in the front.
almost impossible to find a 7mgteu
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
Old 03-26-2008, 08:55 PM   #10
ravenmaster
ravenmaster's Avatar
You can actually mod the 7MGTE engine with slight diffrences to make it to the 7M-GTEU specs.
The turbo was a CT-26A the A being designated by the A on the housing, basically it just is a bigger housing with a Garrett wheel.
The miggest problem you'll have with the mods is that the engine uses a MAP sensor instead of an AFM.
1988 Toyota Supra Turbo Targa
