Old 12-19-2007, 03:21 PM   #1
ScottieB
ScottieB is on a distinguished road
Default 83 to 86.5 engine swap
I was looking for a cheap project to keep me busy this winter. I came across a rust free, straight 86.5 Supra with a blown motor. This guy also has a 83 Celica Supra with a good motor and trans. Will the 83 bolt into the 86.5? the 86.5 is a NA motor.
ScottieB is offline   Reply With Quote
Old 12-19-2007, 06:39 PM   #2
Supra2NR
Supra2NR's Avatar
isnt the swap suppose to go the other way?
as in putting a 7m series motor, into older year supras
cuz i know that the 7mgte can be easily fitted into an mk2 supra
Old 12-20-2007, 04:06 AM   #3
ScottieB
Should go the other way, but I can have both cars for $200. Might as well do it this way because it's so cheap. So, will the 83 motor bolt into the 86.5? Any threads you guys know of that swap from 86.5 to 83? I would be able to tell how much fab work needs to be done.
Old 12-20-2007, 02:29 PM   #4
Chambers
Chambers's Avatar
I don't think you will find much information on that, because most people don't want to put in a 2.8l ~170hp engine in a car that came with a 3.0l ~200hp engine stock. So I would think that you could make it bolt up with a little custom motor mounts if they don't line up, but why?
How blown up is the 86.5s' engine?
"Stuck in the 80's"
Old 12-20-2007, 04:37 PM   #5
Supra2NR
Supra2NR's Avatar
No thread on the 7m mk2 swap
Cuz it was on older guy that did it, and it was at least 5 yearss ago
Old 12-21-2007, 05:50 AM   #6
ScottieB
Thanks guys for commenting. I guess I'll pass on the deal. The 86.5 has a hole in the block. Pretty screwed. It really too bad, the body is totally rust free and straight as a string.
engine swap ! NYTRYDR MKIII Supra 13 08-11-2007 05:37 AM
Help with engine swap. shawn87gta MKIII Supra 5 12-02-2005 01:45 AM
