Old 11-16-2007, 08:14 PM   #1
D_Train
Default how does your first gear pull?
I have a stock NA 1987 manual supra. In first gear when i really give it gas when i drive it to have fun and i bring it to 6k rpm's, i feel lots of pull until i get to about 4.5-5k then the pull doesn't seem so great. I thought we got most of our HP around 4800rpm's tho.
Clutch Slipping?
Old 11-17-2007, 12:01 AM   #2
supradaddy0803
supradaddy0803's Avatar
This is what you call your power curve. Your power will always peak then die off. That is kind of normal with a n/a really mine did the same thing. Now with a turbo you will feel the lag in the beginning and then it will also peter out on the top end unless you put a boost controller on it to take care of that.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 11-17-2007, 02:36 AM   #3
west_side_supra
west_side_supra's Avatar
i'm turbo'd and its like it doesnt even exist :P
7MGTE - 500hp never dyno'd
fidenza cam gears
LSD gear oil suprabahamut Non-Generation Specific Questions 3 05-04-2008 02:40 AM
speedometer drive gear removal Gunnar MKIII Supra 1 01-20-2008 08:24 PM
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
lower timing gear quamme Non-Generation Specific Questions 0 12-12-2006 12:41 AM
7mgte motor pull silude MKIII Supra 4 12-11-2005 04:44 AM
