Old 11-13-2007, 08:23 PM   #1
mkiiisupra
Default Where is this vacuum line saposed to connect to?
coming from the bottom of the accordian hose.
So i am guessing then, that this vacuum line is not routed properly? or is it?
If not what plugs into the metal line that comes out of the bottom of the charcoal canister
1990 Toyota Supra Turbo A/T
Old 11-13-2007, 09:16 PM   #2
supramacist
supramacist's Avatar
There should be a vac diagram under the stock hood.
Old 11-13-2007, 09:21 PM   #3
mkiiisupra
not shown on that vacuum diagram, i have not seen it on any diagrams
Old 11-13-2007, 11:24 PM   #4
dcrusupra
dcrusupra's Avatar
not sure what connects to the charcoal canister but that vacuum line coming from the from the accordian hose goes to a metal line in front of the power steering pump.
New Rebuild
My CarDomain
Old 11-14-2007, 01:25 AM   #5
mkiiisupra
do you have a picture? just went out there too look and im not see'n a metal line for the vacuum hose to connect to arround the pwr steering pump.
Old 11-14-2007, 02:42 AM   #6
supramacist
I don't think it's actually on the p-stump.
I think it's a bit lower and in that immediate area.
But I drive an n/a so I could be mistaken.
Old 11-14-2007, 02:48 AM   #7
mkiiisupra
ya i cannot seem to find it
Old 11-14-2007, 04:18 AM   #8
mkiiisupra
i removed the accordian hose and was able to see that it connects to a valve assy thing on the bottom left pulley thing.
which is broken on the steering pump and on the extra one, way to go toyota make a 175 dollar part outa plastic YEAH!
anyways can anyone shine some light on where that metal pipe off the bottom of the charcoal canister is saposed to connect to?
Old 11-14-2007, 08:10 PM   #9
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
The pipe on the charcoal canister should just vent into the air but it connects to a small hole in the frame. That is how it was on both of my 87 Turbos and also the peice that is broken is on the Powersteering pump is a valve that will go bad after some time.
Is your powersteering hard or does your ps pump make noise?
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Old 11-15-2007, 04:12 AM   #10
mkiiisupra
actually latly its been squeeking or vibrating when i turn the wheel while car is slow moving or stationary
All this after i had someone do my timing.....
Oh ok, thanks for info on charcoal canister
Vacuum line routing to HKS SSQV? mkiiisupra MKIII Supra 8 02-06-2008 05:29 AM
Vacuum line help 91toy supra MKIII Supra 7 08-25-2006 11:32 PM
Vacuum Line Deletion? Bullz_EyE MKIII Supra 1 12-24-2005 06:37 PM
vacuum advance/retard tonster MKII Supra 0 09-16-2005 06:43 PM
Fuel line problem Damian MKIII Supra 1 07-23-2005 10:22 PM
