Old 11-13-2007, 07:53 PM   #1
supramacist
supramacist's Avatar
Default AEM fuel / ignition controller
Has anyone tried these things.
I have a 91 na 5spd 7m series.
My ecu is shot.
Someone mentioned this thing to me on this forum.
I'm wondering if any of you have tried it and will it bypass the ecu??
Please and Thanks.
Old 11-13-2007, 08:36 PM   #2
Chambers
Chambers's Avatar
Depends on if you get a stand alone or a piggyback fuel controler. Piggyback require a signal from the ECU to alter so you can tune your vehicel, a stand alone will just simply replace the stock ECU entirely, good luck.
"Stuck in the 80's"
Old 11-13-2007, 09:15 PM   #3
supramacist
The aem says it needs to piggyback the ecu for climate control.
Being as to I have done an ac delete. The f/ic won't work without that siignal still?? I'm getting mixed reviews.
Old 11-14-2007, 01:31 AM   #4
Chambers
Chambers's Avatar
I just looked over this, AEM FIC, that is what you are talking about, right? Well the overview states "This system works parallel to the factory ECU......" which means it won't work without the stock ECU inplace. Sorry.
"Stuck in the 80's"
Old 11-14-2007, 02:02 AM   #5
supramacist
Yes. That's not what I was hoping for.
DO I need an igniton system and a fuel system?
Is there a 1 pc. unit available for this application?
I'm hoping you know something I don't because my research is turning up notta.
Old 11-14-2007, 02:09 AM   #6
Chambers
Chambers's Avatar
If your wallet feels up to it you can get a standalone ECU from AEM that is completely tunable for $1,700. That way you can eliminate the stock ECU and have a powerfull tool. But other than that, I don't think your going to have much luck.
"Stuck in the 80's"
car cranks, but no fuel or spark mustangtw5901 MKIII Supra 17 04-30-2008 07:48 PM
